Old 07-26-2015, 10:00 AM
IHinIN IHinIN is offline
Nice as always Adam. It looks like you're using a chemical stripper for some of those parts? Tail strip?
Thanks. I'm not sure what brand the stripper is but is works much quicker than sanding and scraping.
Old 07-26-2015, 10:02 AM
Coming right along..... Looking forward to the paint
Me too Todd.
Old 07-27-2015, 05:35 PM
Made a new throttle shaft today to replace the worn shaft.
Old 07-27-2015, 11:54 PM
Very nice. You guys and all those "special" machines you have access, an knowledge to build parts, lucky son's of guns... (very jealous )
Old 07-28-2015, 01:32 AM
nick4030 nick4030 is offline
Love these types of threads. I am new here (and to cubs) but have spent a lot of time on MTF and other ''green" sites. I dont know about VanSickle in cub colors, but compared to real JD paint, its not even in the same ball park, and doesnt hold up nearly as well either. Its your call, but I have seen it over and over again, and done comparisons myself. Your doing a lot of work to be using inferior paints.
Old 07-28-2015, 09:51 AM
rwairforce rwairforce is offline
Excellent.
I wish I could get pictures that good.
Adam,
Novice speaking here....if you are going to blast the parts before painting, why is stripper used too? Thanks.
Randy
Cubs: 71, 72, 127, 149, 1440, 2186 and 1864
John Deere 110 round fender
John Deere 140 H3
Sears: GTV16
Old 07-28-2015, 05:35 PM
I'm still undecided on what paint I want to use. I was thinking of the Vansickle just because I can get it easily and it's inexpensive. The Majic brand I used on my 129/149 took a long time to dry even with hardener.
I've been using stripper to save time and blast media. I also want to avoid the possibility of warping the sheet metal from blasting.
Old 07-28-2015, 10:15 PM
The engine lives again! I did have a dumb@$$ attack and tried starting it with the +coil wire hooked to the negative post on the battery. A coil doesn't work too well with no power going to it. Doh! Once I realized my wiring oops, it fired right up. Now, I can clean it up and shoot some primer on it.
Started working on the hood. I had planned on trying to find a better hood but decided to go ahead and fix mine since the chances are pretty slim of finding a 50 yr old hood that doesn't need work.
Old 07-28-2015, 11:31 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Just a suggestion on the paint.. spend a little bit more and get an automotive grade urethane based paint.. It requires hardener and costs a bit more but it sure does lay out nice and holds up very well.. It dries quickly and does not die back like the equipment type enamel does over time. Years from now it will still look great..
I have used Westin, PPG, OMNI, and Nason over the years.. all with good results..
It's looking GREAT!! Thanks for posting the pics.. I enjoy following your progress!!
Jay
Proud owner of the following:
Old 07-30-2015, 10:04 PM
I'm almost certain I'm gonna use CaseIH paint. I've not heard any negative comments about it from anyone here who's used it. May stop by the PPG dealer and price a lower end auto single stage paint too.
Today, I worked on the tower a little with a hammer and dolly to straighten a couple spots. Made a few patches to fill some extra holes too.
Ammeter gauge hole. My bad.
Switch hole and start of hole sawed spot. PO mod.
Mystery hole below key switch. PO mod.
