Old 01-29-2016, 12:12 AM
bocephus1991's Avatar
I grew up on a quietline too, a 1200 which I have. I rebuilt my steering box, their not hard to rebuild. Looks good!
Brian
Old 01-31-2016, 06:57 PM
twoton twoton is offline
So when I started on this spindle upgrade I wanted to give the tractor a wider stance and was hoping to get a tighter turning radius. So, I extended the weld on spindles out an extra inch one either side, and I added a bit more camber to them, just a couple of degrees. Don’t know what the turning radius started out as, don’t know where it is measured from, (inside of inside wheel, centerline of tractor…) but according to Tractor Data the 1650 has a turning radius of 6.6’. After I got the thrower off today I took it out back and after doing some donuts I measured 4’9” radius to inside of inside front wheel. Sure feels a lot tighter.
Old 01-31-2016, 07:02 PM
Mr Zippel, you actually made me laugh, thanks.
p.s. where'd you get that picture of me?
Jay and Brian, thanks, if I keep driving my Quietlines maybe one day I'll be grown up too!?
Old 01-31-2016, 10:48 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
we all got a kid still buried inside I think!
Jay
Proud owner of the following:
Old 01-31-2016, 11:21 PM
I sure hope that's one thing I never loose
Old 02-02-2016, 12:00 AM
jaynjeep's Avatar
For sure Todd!!
Jay
Old 02-06-2016, 07:18 AM
Default dual stick question???
So which control lever is suppose to control what?
According to Kenneth Updike's book, pg 106,
" The outer lever operates the implement lift, and the inner lever operates the front hydraulic outlets."
Mine is reversed. Always seemed messed up to me. As I'm in the process of adding rear hydraulic ports to this tractor, I thought this would be a good time to switch it. Sure seems like the hard lines to the front outlets are formed perfectly to match up to the left side of the valve (which is where they are). Does the stock valve use SAE O ring to JIC fittings? That's what this one has. Just wondering if this is a PO mod?
Old 02-06-2016, 08:57 AM
My 1650 is like yours David, seems backwards.
Old 02-06-2016, 09:40 AM
budscub's Avatar
budscub budscub is offline
Default Same Here
When I got my dual stick 1450, I too was surprised that the inside lever, ( the added auxiliary handle) actually controlled the deck lift. I suppose I was expecting the deck lift to remain on the "bent" lever handle rather than being on the added handle. I believe yours is correct to factory.
Gary
1974 1650 50A "budscub" Was my fathers
1969 125 42"
1978 1450 44A dual hydraulics
1984 782 50C dual hydraulics, waiting for vanguard
Z-force Cub cadet Zero turn
Sears '66 Suburban 10 Sears '66 Suburban 12
2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow
74 "Green 100 "John"
Old 02-06-2016, 09:50 AM
mortten mortten is offline
Operators manual say the inner one is the lift handle, the outer the front outlet control
