Old 02-22-2016, 08:33 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
Welp the 18 is about done. Got a different head for the number one side of the engine after we found out the push rod on the exhaust valve was bent and blew the seat out of the exhaust valve. Only to find out when we got the different head the female thread that hold the rocker arm were stripped. After talking to Jmech, we ended up helicoiling the threads. Re torqued everything assembled all the pieces, replaced necessary gaskets, push rods obviously, and now have a what seems to be good running CH18S.
Had to do a little work to the plastic that I purchased, but it is pretty decent overall. Keith ended up doing a little different fix to the headlights but turned out to be a very good repair for the broken stubs that hold the headlights on.
Got the hydraulic outlets put on and just ordered the 3 point lift rod from xtreme today. Other than waxing and trying to put a shine on the plastic, a decal kit is about all that's left short of a seat cover. Otherwise is a functioning operational 1864 again!
Tonight Keith and I moved the 54 inch deck to the shop. He even started tearing it apart, so hopefully we can get it put back together before the grass starts growing :-)
1- 1200 in pieces
1- 1864 in pieces
Old 02-22-2016, 09:50 PM
Dirty Steve's Avatar
Great job saving the 1864. They are worthy machines. So about those add on hydraulics....
Old 02-23-2016, 09:33 AM
Nightow1 Nightow1 is offline
Getting lucky on the deck, the spindles were frozen up so I was a little concerned, but after removal and a good cleaning they are perfect just packed solid with old dry oil, just need to put new seals in. A little work on the spindles and some new wheels, and she will be.good to go. Not a bad deck.
Old 02-23-2016, 09:38 AM
Originally Posted by 1811woody View Post
You said you've done some waxing and buffing, no painting? Its going to look like a new tractor. Nice motor stand also.
It's an awsome stand. Still have a little work to do on it. I have a control panel made so i can twst run engines on it and Rescue11 is going to put a 3pt attachment on it so i can move it from place to place alone. Another nice thing is it's sealed under the.engine so I can drain oil in it and drain it out theough the bottom. It's just a great design.
Old 02-23-2016, 11:04 AM
Rescue11's Avatar
Very easy to do. Little pricey on getting stuff rounded up, but its all relative. Liking your 2182 progress! Hard to prt those machines aint it!
1- 1200 in pieces
1- 1864 in pieces
Old 02-24-2016, 09:39 PM
Rescue11's Avatar
Keith has been busy!
Re built the spindles, now waiting on a few parts.
Ordered a seat cover yesterday. The ol girl is comming together!
1- 1200 in pieces
1- 1864 in pieces
Old 02-24-2016, 10:10 PM
1864 is coming together, you guys are a great team
Never know what's coming out of the shop next
Old 02-25-2016, 10:48 AM
V30crewcab V30crewcab is offline
A white fuel tank? That's interesting, my 1862 has a black one. Must've switched suppliers.
1782, 1862, 1440(sold), 89 1050, 128, 70, some run some don't!
72 scout
IH 404 tractor
Old 02-26-2016, 07:49 PM
Well Rescue came over and installed the lift arm for the 3pt nd the older R_ Bucket . All and all the tractor came out awsome. Heck of a little cub.
Old 02-26-2016, 11:18 PM
Sure it's not just dirty? Never seen a blank tank on any of the cyclops....
