Old 01-26-2016, 08:59 PM
adamo adamo is offline
Post a pic of you battery.
Pic of battery and I believe someone else asked for all the connections so I took a pic of the distributor.
Old 01-26-2016, 09:07 PM
Do you have a headlamp for a car around? The old glass (like a incandescent) style?
Or perhaps does this 129 have a working headlight?
Old 01-26-2016, 09:22 PM
Yes I have headlights on the 129. They work!
Old 01-26-2016, 09:35 PM
Ok
Do this:
Remove one of the headlamps (Ok, so you don't have to remove it, but disconnect it.) Make two wires for it. Run one wire to a good ground, or the battery neg. (Or just leave the negative wire attached to the light.) Run the other to the "A" post on the S/G. (Make this wire long enough to reach the battery. We may need to test other stuff here later.) Don't attach it permanently. Hit the key to start it. Does the light light up? If yes, how bright?
Old 01-26-2016, 09:36 PM
budscub's Avatar
budscub budscub is offline
Default I still suspect the battery cable
Hey J-mech, correct me if I am wrong, but if he jumps the two large terminals with a screw driver, does that not leave only the battery cables,, battery itself, or the starter generator to ground to be at fault? If the starter generator is good.
I was looking back at the photos, in the one photo the terminal on the Positive battery post doesn't look like a good crimp. Of course it is difficult to tell in the photo, but the cable looks swollen just as it makes the turn coming from the battery, looks like it maybe full of corrosion.
Gary
1974 1650 50A "budscub" Was my fathers
1969 125 42"
1978 1450 44A dual hydraulics
1984 782 50C dual hydraulics, waiting for vanguard
Z-force Cub cadet Zero turn
Sears '66 Suburban 10 Sears '66 Suburban 12
2 Breaking plows, 2 disc's, front blade, rear blade, Sickle bar mower, 2 decks 3pt harrow
74 "Green 100 "John"
Old 01-26-2016, 09:39 PM
Yes, you are correct..... BUT:
This is a teaching moment. Instead of using a tool and try to burn something up, I am going to teach everyone how to test a circuit using wire and a headlamp. Use the headlamp because it has a somewhat large load. Much larger load than a test light. This way, if the light is dim, we will know if the voltage is low. Sure, we could use a meter, but sometimes a meter will lie. One good strand in a wire will carry 12V, but it will not light up that headlamp. In 2 or 3 short tests, we will know exactly where the issue is. No guessing.
It will be fun.
Old 01-26-2016, 09:58 PM
budscub's Avatar
Default agreed
Thank you sir, Nothing like teaching them to fish. Good Idea using the head light.
Gary
1969 125 42"
Old 01-26-2016, 10:14 PM
Ok
Do this:
Ok! Nice and bright when I turn the key. Also know that I attached the negative to the ground post to the frame from the SG.
Old 01-26-2016, 10:20 PM
So, with the light hooked up to the "A" post of the starter, you hit the key and it lights up. If that is correct, your starter is bad/broken.
Just a quick test, disconnect the "test light", hold the key in the start position, take a hammer and give the S/G some "love taps" on the side. Does it try to turn/ start?
Old 01-26-2016, 10:46 PM
Except when I run jumper cables from a battery to the s/g it turns over. It is with the A terminal lead disconnected from tractor.
Tags
129, electrical probs, no crank
