Old 04-02-2016, 06:27 AM
Dirty Steve's Avatar
Amazing attention to detail! Can't wait to see it all together.
Old 04-02-2016, 09:20 AM
Thank you guys....i cant wait to get it together either...this sortof resto is just kindof tedious, whereas the next one on the dockett is gonna be a worker.....oak, i might have some diesel questions for you as you are the the go to guy.....and maybe some moldboard plowing too!!!!
Anyways rear wheels are in primer,(seam gone) gonna try to squirt this weekend and finish mud and primer and block sanding on fender pan....
Heres somemore pics of that oil breather vent...just a cut barb, but i like it better than the hanging hose, and the grass sheild, or bottom plate i just put a .625" hole for clearance.....
Thank you fellas.....
Old 04-02-2016, 11:04 AM
Same here.
Old 04-02-2016, 04:14 PM
Thanks guys, thank you allen!!!
Old 04-02-2016, 04:16 PM
Quick question: i know its not original but i put a float bowl on the tank, and have ran 3/16" hard brake tubing for fuel line....is this stupid, and gonna leak????
Old 04-02-2016, 04:57 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
should work. but it would be disappointing if it did, nice work
Old 04-02-2016, 05:00 PM
garnold's Avatar
garnold garnold is offline
Originally Posted by mjsoldcub View Post
Some shots....the dual condensers im hoping is going to help with points longevity in running a hotter ign....it also has new style piston and rod with rod and cap offset bored for a continental (engine) bearing and a little pop out...head went .020" down with a fly cutter, valves ground, seats dressed, bronze inserts put in guides..i opened up the intake runner to the 30mm also....the original exhaust was there but just not salvagable in my mind so ill have to show you what i came up with for 31 dollars and see if anyone can tell..(well after paint anyways)....i also had a gentleman at redoyourhorse.com make up the original engine tags with MY #s on them...super high quality, like theyre printed on aluminum...nice guy too...anyways
Holy cow man, my head is spinning just trying to understand all this! Amazing work!
108 upgraded to 12hp
127 with all the trimmings
73 WIP
75 WIP
Blade, blower, decks
Tons of left over parts
Old 04-03-2016, 04:06 PM
Jeff122's Avatar
Jeff122 Jeff122 is offline
WOW is an understatement. Remarkable workmanship. Wish I had the talent as well as the time and resources. Absolutely amazing!
Old 04-03-2016, 08:34 PM
ccguy's Avatar
ccguy ccguy is offline
Better than factory...a lot better!
INTERNATIONAL HARVESTER
- We build the machines that work.
1811/682/782/1440/IH #4/IH QA 42"
Old 04-03-2016, 08:38 PM
Amazing, looks great.
