Old 07-24-2016, 01:03 PM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
Well, it didn't start this morning :/
Originally Posted by twoton View Post
Believe it or not, on occasion bolts have been known to vibrate loose on these machines, so.. check your battery B- cable to chassis connection for a good ground. I had one fuel tank that had been sitting with old gas in it for an extended period of time and the in tank screen became clogged on the lower section. Tractor would run to 1/4 tank and then die. Also, wouldn't be the first time that a spark plug just up and failed.
Bolts rattle loose?? Nah.
Is the B- the large wire that bolts to the grill/frame? If so, it's good. All the wires on the coil were tight. So I don't think it was any of those.
I didn't look real well into the fuel tank. That's a possibility I suppose. Although I think I smelled fuel after I cranked it a little bit.
I just replaced the spark plug when I bought it, so I doubt that's it, but certainly not ruling it out completely. I have a new one ready for the 149. I'll try that too.
It seemed to turn very quickly, so I'm thinking maybe it's a valve. Should it fire after cooled down if it's the valve?
I took the coil and condenser out and brought it home. I'm going to try and bench test it. Does anyone know what resistance I should get on each coil? How do I test the condenser?
My 149 runs, could I take the condenser and coil off it and swap to see if that's the issue?
Here is a video of it turning over. It seems a little quicker than normal. Thoughts?
https://youtu.be/BZli-tNS0vQ
If I get the 149 running well, I'm ordering the PTO parts so I can put it into commission. Then I'll haul the 1200 back to my house so I can tinker with it, if it's not something simple to fix. I REALLY don't want to take off the head and mess with valves.
Thanks everyone for the help!
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
Old 07-24-2016, 01:46 PM
bocephus1991's Avatar
http://www.onlycubcadets.net/forum/showthread.php?t=11
Here's a link to testing the coil
Brian
Old 07-24-2016, 01:57 PM
Tom4981's Avatar
Tom4981 Tom4981 is offline
This has been an unbelievable discussion the knowledge being discussed has been very impressive
Old 07-24-2016, 02:15 PM
vr4Legacy's Avatar
Originally Posted by bocephus1991 View Post
Thank you sir!
It shows 1.1 ohms on +/- and 8850 on +/tower
So, it looks like the coil is bad. Hopefully that's the only issue.
Should I swap the one from the 149 to test it out? I tested it, and it was aprox 4.5 and 9500.
I plan on getting them both running, should I just bite the bullet and buy a new coil, since it seems the one off the 1200 is bad anyway. Remember, the 1200 is outside of town in a field, I'd rather not run out there to test a part I'm pretty sure is bad.
From what I've read there isn't a good way to test a condenser with a digital meter. For $6 should I just get a new one?
Any suggestions on manufacturer? Here is what i"m looking at right now, because Prime.
https://www.amazon.com/gp/product/B0...A16MP6R2VB2XI3
Condensor
https://www.amazon.com/Prime-Line-7-...k301+condenser
-Jason
Old 07-24-2016, 02:27 PM
twoton twoton is offline
What's the ohm rating on that coil Jason?
http://www.onlycubcadets.net/forum/s...707#post343707
Old 07-24-2016, 02:32 PM
This is nothing new....must be 300 threads on the same thing.
Stens parts are fine, but make sure it is the correct OHM rated coil. I doubt it's a condenser. A bad condenser will still fire, but usually runs rough.
I'd pull the coil off the 149, take it out the "field" and get the 1200 going, then bring it to a more suitable place to work on it.
What's wrong with just getting a coil off of a parts store? I order online too.... stuff I can't get locally. Doesn't matter, I just think it's funny that people now days would rather order something online and wait 3 or 4 days to get it. My local parts stores can usually have most everything the next day, and I'm rarely not in town. Or, they will deliver to me... but I'm "special".
Old 07-24-2016, 03:04 PM
vr4Legacy's Avatar
Thanks, I may grab a condenser just to have as a backup, but I'll keep the one I have for now.
In my case, with work and family, it usually takes me 2-3 days to get around to going to an auto parts store. By then, with Prime shipping, the part is already at my door. Plus the local stores i goto have people that don't know what they are doing. Since they can't look up a Cub Cadet 1200 on their computer, they probably couldn't find the part I need, even with the numbers. It took me 5 minutes to explain to a guy that I needed 3/8" fuel hose for my lawn tractor... Then he said "oh you mean carburetor hose?"
Honestly, if I could find an auto parts store with employees that acted like they want to be there and help me, I might go there even if it costs a couple bucks more. But I haven't had much luck in that area.
Thanks everyone for the insight. I'm out of town Wednesday thru the weekend, so it may be another week before I get back out there. I'll check out Advance and see if they have the part in stock tomorrow, if they do I may run out tomorrow night just to see if it works.
-Jason
Old 07-24-2016, 03:07 PM
vr4Legacy's Avatar
Which one? The bad one is 1.1 The one on the 149 is 4.5
Proper range is 4-8 according to this
-Jason
Old 07-24-2016, 03:09 PM
I think he mean, what is the OHM rating of the coil you posted on Amazon. It doesn't say.
I must just be blessed in my area as far as parts guys go. Besides.... I usually go in with a part number. They people are willing to help, but I can find part numbers faster than they can (if one of the "good" guys aren't available).
Old 07-24-2016, 03:30 PM
Jason, Should be 3.2 to 3.5 ohm, internal resistor coil like this one;
https://www.amazon.com/dp/B001CO4WA2...I12BTRZ0XVWXGC
Jon's right, the one in your link does not list an ohm rating. Not to say that it is not the right coil. I bought a Bosch Blue last year for my 1200. Tractor died just like yours after mowing for about 2 1/2 hrs. Brought in an old coil from my parts tractor and it fired right up, still running. So the point is that the more expensive coil is no guarantee of quality.
