Old 05-22-2010, 01:27 PM
aagitch's Avatar
aagitch aagitch is offline
Saturn my fault I was calling the main the one that clamps. The inline will only be around 1/2 to 3/4 full even when running so that's not anything to worry about.
Old 05-22-2010, 09:47 PM
TheSaturnV's Avatar
Yeah, I worked on bleeding the lines and figured out there was no way to get all the air out of the inline. I'm getting better at purging the various points. It's running better and better.
I don't know what to call it, but there is a small port on the front side of the injector pump. It looks like a miniature stud with a spring attached to the end. It has a slot on the end for adjusting with a flat head, and it runs through a nut. I pulled it out to have a look, and it was covered in motor oil.
I assume with the spring and slot, it is supposed to be adjusted, then the nut can be tightened to hold it in position. I don't seem to be finding anything in the manual about it. Anyone know how to set it?
Old 05-22-2010, 09:58 PM
Amigatec's Avatar
Amigatec Amigatec is offline
If it's sucking air somewhere you will have to find it. If it isn't the air will self bleed.
Pat Benner Haskell OK
Old 05-24-2010, 01:03 PM
TheSaturnV's Avatar
My Messicks order showed up much sooner than expected, so I was able to install a new throttle cable, which has cleared up most of the remaining quirks, and taken the guesswork out of where to set the throttle on startup. With this new part and some more time spent on learning to purge the system, the old girl is now starting and running pretty reliably. For grins, I picked up a shiny new throttle knob that won't keep falling off, plus I went ahead and replaced the plastic bowl that holds the paper filter/element just before the injector pump. The old one was still serviceable, but was really yellowed and seemed to be getting brittle. You just know it would have decided to crack apart over a weekend, bringing the machine down. I installed the new one, and set the old one aside as a spare.
Old 05-24-2010, 04:16 PM
Iluvtruks0's Avatar
Glad she is running a lot better now. Enough time, effort and TLC goes a long way. Mine should be up and running this week. If not, it will have to wait a week till I get back from a business trip.
David in NC
