Old 09-01-2016, 04:54 PM
Originally Posted by SGragg View Post
Thanks, Randy. I was thinking a gallon of the 2150 Case-IH red and (2) quarts of primer.
Sounds good, I don't paint for a living anymore but I work at a bodyshop and still know what I am doing for the most part. LOL. If you need any advice or anything, let me know.
Randy
2 original cub cadets
1 100's
2 149's
1 73
1 2182
Old 09-06-2016, 09:52 AM
SGragg SGragg is offline
Inactive Member
Made further progress over the Labor Day weekend. Got the frame, hood, side panels and fenders all stripped. Used a combination of twisted wire wheel, twisted wire cup brush and flap sanding disc on the 4" angle grinder, along with an orbital sander (#80 and #120 grit). Makes a huge mess, but hey, what doesn't?
Have a structural question for y'all: Does the crack in the front aluminum frame need to be welded, or can I JB Weld it? Appears the PO ran into some immovable object and cracked the frame/nose. The crack is only on the top molded piece (as shown). It doesn't run all the way down to the lower piece.
Hope to shoot primer this weekend. We'll see...
Stanton
1980 IH 782, Kohler M18
IH #1 Cart, original
2015 XT2, Kawasaki 23 HP
Old 09-06-2016, 11:01 AM
Terry C's Avatar
Terry C Terry C is offline
I would weld it. I've welded up a couple of 82 grills and turned out nice. I would guess they used a similar material.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 09-06-2016, 11:12 AM
Appreciate the update, Stanton!
Old 09-06-2016, 11:28 AM
yeeter yeeter is offline
Great progress! That engine cleaned up nicely.
Old 09-06-2016, 11:47 AM
Inactive Member
I believe the front frame to be aluminum, therefore, I cannot weld it at home (MIG). If it needs welding, I'll need to take it to a welder.
Stanton
Old 09-06-2016, 12:53 PM
Terry C's Avatar
Yeah you have to tig it but I think you should because that crack got all the way to the edge. I think it will continue if you don't weld it. Just my 2C
Terry
3225
Old 09-12-2016, 08:16 AM
Inactive Member
Took the front frame to have it welded and got it back. Ground off the weld and all is good. The weather was beautiful over the weekend, so got all the major pieces primed. Next weekend is forecast for the same nice conditions, so hope to shoot some red paint then.
My NOS hour meter also arrived Saturday!
Stanton
Old 09-12-2016, 11:02 AM
Terry C's Avatar
Looks like things are progressing nicely!
Keep the pics coming.
Terry
3225
Old 09-12-2016, 11:28 AM
Excellent work, Stanton! Enjoying your pics and updates.
