Old 12-10-2016, 09:47 PM
Originally Posted by taylorjm View Post
Because the axles are not perpendicular to the frame. They are turned in a bit.
Then you don't know what the toe in is....
Old 12-10-2016, 10:16 PM
Terry C's Avatar
Terry C Terry C is offline
Easiest for me is a set of wheels with no tires on them.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 12-10-2016, 10:24 PM
Rescue11's Avatar
Rescue11 Rescue11 is offline
X2, you have to put wheels on to accurately measure toe in. If you measured the toe in from the spindle shafts, whenyou put the tires on, you're going to have wayyy too much toe in.
1- 1200 in pieces
1- 1864 in pieces
Old 12-10-2016, 10:26 PM
taylorjm taylorjm is offline
Thanks for the advice. I'll check and see how much toe in I have when I get the tires back on. I can see what your saying about it becoming too much once the tires are on.
Old 12-10-2016, 10:46 PM
Again, if you would look in the book......
Old 12-10-2016, 11:04 PM
Originally, I tried to align it with the tires on, but they were wobbling too much due to worn out bearings, so I took the tires off. But once I get new bearings, and get the tires back on, I'll check it again and fine tune it if needed.
Old 12-10-2016, 11:22 PM
Rescue11's Avatar
That will make alot of difference
1- 1200 in pieces
1- 1864 in pieces
Old 12-13-2016, 05:48 PM
What else I found will make a big difference is that one of the axle jam bolts were loose and moved a lot, so the axle was not only moving up and down, but side to side. I looked all over the manual and couldn't find anything referencing how to adjust the jam bolts, and didn't even know they existed until I found another post that mentioned them. I tightened them up so the axle can still move up and down, but not side to side, which common sense would make me think is correct.
