#41
I have not yet removed this new inner bearing from the new front rim. But I will share what's discovered. The new bearing feels and sounds bad, and can't understand it's final demise. Got out and got some yellow sprayed down, and that's about it for a Sunday!
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
#42
Picked up my 8.5"x12" rear rims from the sandblasting shop. I'll post up some pictures, and give the shop a plug:
Newbury Sandblasting & Painting P.O Box 378 9992 Kinsman RD. Newbury, Ohio 44065 440-564-7204 Going to clean the bare metal, and shoot some primer a.s.a.p. !
#43
Nothing like a good set of Firestone rims for my new tires!
[/IMG]They were pretty clean, and so I cleaned them further by spraying alcohol on then, and drying with compressed air. [/IMG]Now in red primer. [/IMG]Some of the disk brake components painted in yellow, my favorite color! [/IMG]Took me one time to remember why you don't use light grey primer under yellow paint. Oh well, what's done is done. [/IMG]The two spindles finally got what they deserved, lol! [/IMG] [/IMG]
#44
I love the attention to detail! Great work!
'74 IHCC 108 - 38A, supersteer axle '75 IHCC 1000 - 44A, Sears wheel weights '87 CC 1872 and 1811 - Haban, 44C '96 CC 1863 - 54GT '79 JD 400 - 60" deck "Projects" '67 123, '65 102, '71 126 |
#45
Its going to pull together pretty well! There are things I plan on doing to the 1450 that will make it a better than factory garden tractor.
Thanks
#46
I apologize for the bigger than needed pictures above. Darn- something went crooked on me
![]() Well, here are the Cub Cadet valve stems for my rear rims. Part number on the bag. Price was $2.18 each. [/IMG]Also today, I got some paint for these rims. Thought about the Cub Cadet white, but at $16 a can, and plus the fact of getting the new tires on the rims, there is going to be some paint screw-up's happing. $5.29 from local hardware, recommended for lawn and garden equipment, and will have some left over to correct the paint work to the rims after tire install. It's pretty good for a rattle, as I've used it before ![]() [/IMG]Paint is: Krylon Rust Tough #RTA 9207 Almond
#47
Paint the inside of the wheels, mount your tires. Tape off the tires, then paint the outside of the wheels.
![]() GUARANTEE you, that paint will not hold up to mounting the tires after painting, no matter how careful you are.
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
#48
#49
I removed the inner wheel bearing that was bran spanking new, from my front rim that also was bran new. This is what I found:
![]() I knew I was hearing something, but never suspected it to be these components. Well, I went on to install the replacement bearing and all is well here. I recall having a problem with the cap screw that goes through the large washer and into the wheel spindle securing the rim to the spindle. Darn cap screw would constantly back out, resulting in a loose everything. I'm almost sure I over tightened the cap screw and this was the end result. Now, I'm thinking if the cap screw does this again, I might try to put a mar in the threads to prevent the back out from reoccurring. I also installed to my 1450 the freshly painted wheel spindles. I have the drag and tie rod drying in yellow and hope to get those on the tractor later today. I got the insides of the rear rims painted in off white, and new stems put in as well. ![]() [/IMG]
#50
Engine bay cleaned up, spindles, tie rod, drag link, and front wheels cleaned and back on the 1450!
[/IMG] [/IMG]
