Old 08-25-2010, 08:25 PM
IHinIN IHinIN is offline
We use steel tubing at work for hydraulic lines on machinery. I got the tubing and bender from work and then took the lines back into work and flared them.
Old 08-25-2010, 10:57 PM
cadetfarmer cadetfarmer is offline
Default hydraulic lines
IHinIN;
So if I have equipment that will bend and flare steel tubing, what quality steel tubing would I need to make hydraulic lines.
I used to make brake lines for medium duty trucks, (like C50-C60 Chevs, F700 Fords etc.) would those lines be strong enough to handle the pressure of my hydraulics, where can I buy tubing that will work?
I would like to do something that looks as cool as yours does, and big ole hoses hanging on my tracto just doesn't do it for me.
Cadet Farmer
P.S. any advice would be much appreciated
Old 08-26-2010, 05:08 AM
Brake line tubing would work. It should be rated around 2000 psi or maybe higher. Make sure you get the right fittings on the ends to fit whatever fittings you use on the valve, pump, etc. If you have a local hydraulics supply store, check with them and see if they sell the tubing and fittings. You might also check the McMaster Carr site and see what they have. I know they sell all kinds of tubing but I'm not sure about fittings.
Old 08-26-2010, 08:46 AM
Default hydraulics
IHinIN;
No such thing as a hydraulics store here, closest we have is the local Farm Store, out here in BFE. I will check out the Mcmasters site, but will probably end up using brakeline tubing.
Thanks for Your Input;
CadetFarmer
Old 08-28-2010, 08:03 PM
CubDieselFan's Avatar
Check out this Cub with a diesel and 3 speed gear box. The deck lift is hydraulic and it has power steering. It looks to be factory. Did not know they made like that.
http://cgi.ebay.com/ws/eBayISAPI.dll...STRK:MEBIDX:IT
Old 08-28-2010, 08:37 PM
That is not factory. This was discussed previously on here. Someone put in a gear drive rear and added a hydraulic pump to run the hydraulic lift.
Old 10-14-2010, 05:50 AM
I got the cylinder, lines, and levers painted and put back on. I also added a filter to the system. It's a power steering filter I picked up at Autozone. I'll post some pics later.
Old 10-14-2010, 05:00 PM
Here's some pics.
Filter mounted to gas tank bracket.
Old 10-14-2010, 07:23 PM
mrcubcadet's Avatar
Here's some pics.
Looking good, Adam!
-105___ Tiller
Old 10-14-2010, 10:27 PM
That's some top notch work right there!
