Old 07-04-2017, 05:53 PM
I just dropped a new CH22, new PTO and a brand new 54" deck into this 1864. It was worth it to me, pretty much a new machine. It should outlast me.
Old 07-13-2017, 06:19 PM
Beags86 Beags86 is offline
Still doing it
Old 07-13-2017, 07:12 PM
CubDieselFan's Avatar
Originally Posted by Beags86 View Post
Still doing it
Did it overheat again?
Old 07-13-2017, 08:51 PM
ironman's Avatar
ironman ironman is offline
This may sound stupid because it is so simple but I have seen it happen before.
On your gas cap there is a vent hole to let air into the tank so that it can let fuel flow out to the carb. I have seen that vent hole clogged up with minute dust to the point a vacuum is created in the tank and fuel will no longer run out and the engine dies after a few minutes just when every thing was goin' right. Try running a while with the gas cap loosened and see what happens. Just sayin....
Old 07-13-2017, 10:30 PM
Yes, it starts to die after a few minutes of run time.
It takes longer now but it still does it.
Old 07-14-2017, 07:58 AM
I'll give it a go.
Old 07-15-2017, 09:09 PM
Mowed today, mowed for awhile and it died. So I started it up again and kept at it.
Took the side panels off again and kept at it until I had to stop for some errands.
Went and did those, came back about 6 Hours later. Mowed some more and now it died with the side panels off.
Something other then it just getting hot is the problem here.
I think it has some sort of fuel issue.
Tomorrow I am going to read the plugs, and see if there is some sort inline fuel filter that might be plugged.
I'll see if the plugs read rich or lean, and I might adjust the fuel mixer screws.
Other then that I'm out of ideas....
Well I have an old moroso fuel cool can from my race car I'm currently not using, maybe I'll hook that up and just dump some ice in it when I mow.....haha
Old 07-15-2017, 09:11 PM
I'll give it a go.
Tried it.... Nothing
Old 08-10-2017, 10:24 AM
So no one else has any input on this?
Old 08-10-2017, 10:37 AM
How did you check to make sure there isn't a nest in the blower housing?
Pap's 100
Restored 108
1211 Dual Stick
1050
