Old 09-09-2017, 07:59 PM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Originally Posted by smalljob View Post
Had a little time this afternoon to make some progress. I did a dry run ( no gas but yes I have oil ) and it does turn over so at least I have the SG wired partially correct. As a reminder when I got it wiring was not complete, no SG, no throttle cable and of course not running. For now I have not connected up the choke cable because it hangs off the Oil bath filter which I have not mounted yet. It is all cleaned up and painted, but I figured if I have to tinker with this I don't want to have to take it on and off. The throttle cable is way too long but good enough for testing.
Hopefully tomorrow I will set up the fuel tank remotely so I can run it until warm so I can re-torque the head. A lot of variables on this one since it was not running. Rebuilt engine, used S/G, rebuilt carb, no idea if coil is any good.
What is the correct color of the S/G. In my research I am seeing both black and yellow. I made my 100 yellow, but kind of liking the black????
Looking great!! The SG should be yellow on an "O". They started leaving them black later on.. Late 1969 I think.. but I'm like you .. I kinda prefer the look of the black SG.. leave it as you please.. it's your tractor!
Jay
Proud owner of the following:
Old 09-09-2017, 10:48 PM
Can't resist posting a picture of the SG for you..
Looking good, keep at it...
Old 09-10-2017, 08:33 AM
john hall's Avatar
Here is an advertising leaflet for an "O". Not certain the year, came from the dealer dad worked for, notice the red ink stamp with the dealers name. Generator looks yellow. I notice in the "color" picture (is that a lithograph, not familiar how things were done then), that the front wheel bolts were yellow. Is that correct or did the art department touch up the photo?
2072 w/60" Haban
982 with 3 pt and 60" Haban
1811 with ags and 50C
124 w/hydraulic lift
782 w/mounted sprayer
2284 w/54" mowing deck
Old 09-10-2017, 09:21 AM
smalljob's Avatar
smalljob smalljob is offline
Thanks guys
Zippy,, every time I look at your pictures I am amazed at the quality of your work ...... Awesome.
One more question for you. I want to put the copper fuel line in, but my fittings on the carb and sediment bowel are for rubber hose, which is fine for now. Did you find those somewhere or did yours originally have them? If you did make them up new where did you locate them.
Thanks
Bill
Old 09-10-2017, 11:22 AM
smalljob's Avatar
Got it running this morning. Not happy with the carb, very touchy. I have another carb and I threw that on and it worked much better. Need to take a look at that. Also the governor disk is sticking when I idle down. Probably have some paint that needs cleaning off. Will take a look at the carb again. I have good solid spark and it is charging so overall not too bad.
https://youtu.be/Rob_D9vumYc
Old 09-10-2017, 11:27 AM
Motor sounds good! Good work so far!
Old 09-10-2017, 11:02 PM
Thanks
Bill
Bill, you talking about the "elbows"? I'm pretty sure I got them from the Master of Lew.
The line I made...
Old 09-11-2017, 01:50 AM
smalljob's Avatar
Sorry still relatively new here. Who is Master of Lew?
Bill
Old 09-11-2017, 03:47 PM
smalljob's Avatar
Went to local ACE hardware store and picked up the elbows and a piece of copper tubing. Now I have to practice my bending without kinking it
Old 09-11-2017, 11:34 PM
Bill
WHO is Lew? Darkminion
Oh okay, thought you were looking for original style.
