#41
Coming along, you are doing a heck of a job.
Keep those pictures coming.
Up to 534 and counting... I give up updating my profile! |
#42
MattC and Chad 126 your not alone I also have a 126 and a ford YT 16 the ford of mine Is unfortunatly in very poor condition and is currently in my parts/wrecking yard the 126 is waiting for its turn to be restored your 126 is coming along very nicely Chad keep up the good work.
#43
Thanks for the compliments darkminion and Riley. Much appreciated.
I got the carb kit and sediment bowl gasket last night. FedEx delivered them both at around 8:40 so I did the carb rebuild as soon as I opened the packet. I will say I had a hell of a time unscrewing the brass fitting that goes up into the fuel intake port. It's the fitting that houses the brass needle for the fuel shut off in the bowl. Couldn't get a standard socket on it because of the design of the carb. Tried a metric socket and managed to barely fit it into the walls of the carb and backed it out, replaced it, and put the seals on. I've attached a pic of the valve Im referring to. This is NOT my carb. It is just a pic I found of one online for reference. Mine is MUCH cleaner. ![]() I guess it isn't so rare to own a 126 and YT16 after all! It's pretty cool that we have the same little tractors though. I read that they only made about 5000 of the 126, so I would have thought it was more rare, but I'm glad to hear that I have good taste
#44
I have good luck getting those out using a bit driver socket. It’s just a touch thinner than a regular socket and fits in there pretty well.
125, 127, 2x IH 682, 2x IH 782, 2084, 3225, 2x3240 |
#45
I didn't think about that... wish I would have. I'll know next time though. Thanks for the tip
#46
Tires came in today. Hope to mount them tonight. Plan on mounting then taping them off then painting. Maybe they will be painted by this weekend. That should give me time to paint the hubs and let the rear wheel bolts set in some vinegar so they can get painted. Forgive me for still having the halloween decorations up... Cub work > Decorations
#47
I have a cheap 1/4” deep well socket that I use to get those “jet wells” out of the carb like what you have pictured. You just thin out the socket on the bench grinder and your good to go. So my problem is getting that jet well out of my 125. The previous owner had stripped it out so now it don’t turn out!! Keep up the good work on the 126!!
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
#48
#49
Got the tires on the rims after some choice words.
Can't get the dang things to seal to take air. I've contemplated using the ether and fire technique. Anyone against it? I usually try to stay away from explosive (literally) solutions, but everything I have watched on youtube and read about online appears to work great. Of course I will be safe and keep a distance. Thoughts?
#50
Try putting a ratchet strap around the center of the tread. Tighten it up and it should push the sidewalls up against the rims so that you can start to inflate them.
Stand back very far and use face/eye/ear protection, if you decide to do the ether big bang method, but would highly recommend against doing that.
The Collection, so far: Cub Cadet 100(x2), 125(x2), 123(x2), 70, 71. Adding more when I can find them.
