#41
Keep us posted on your progress Sam.
#42
#43
A before and after bath pics of Pig Pen. Looks like the seal behind the flywheel was starting to leak so that's on the to do list.
#44
Parts on order. Should make a nice machine for someone when its all done.
#45
Looking good and clean. Do you use steam or just a pressure washer?
#46
#47
Finally got off my lazy butt and replaced the seal behind the flywheel. Removed the throttle limit screw so now it's a CH20. Now to clean and repack the CV joints for the drive shaft and the tilt steering. Then on to rewiring and new gas lines. I removed the fuel shut off solenoid with the intention of cutting off the plunger but someone else beat me to it, LOL.
#48
1- 1864 Dual hyd, cat 0, axle braces 1- 1450 Dual Stick w/ power steering 1- 1200 in pieces 1- 1864 in pieces QA36A Thrower, #1 Tiller w/ extensions, IH windbreaker, IH wheel weights, 44C mower deck, 50C mower deck, CCC 54" Blade, GT46 high vacuum deck, GT54 deck, Cub Tripple Bagger, Custom dozer blade, Custom suitcase weights, 3pt cultivator, lawn sweeper, original R-Bucket |
#49
![]() The shutoff solenoid just prevents the engine from starting when it fails or doesn't have sufficient voltage to open when cranking. You can't remove it completely unless you have a block off plug. You just cut off the pintle and reinstall it.
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 JD 2155 w/ 175 loader |
#50
Pic show the limit screw and fuel shut off.
