Old 08-03-2018, 11:25 PM
Looks good, glad you decided to remove the extra "stuff", and do this right.
Old 08-04-2018, 07:27 AM
IHCubCadet147's Avatar
Thanks, Todd.
Old 08-04-2018, 07:37 AM
I'm kinda late to the party here...
Did you tighten up the front axle "C" channel before painting?
Also, I'd figure on new tie rod ends all the way around and a new axle pivot pin and maybe even bushings if they really need it.
Go through the steering box and tighten it up, replace parts where needed, like the cam follower, and add the "super steer" bearing kit as well.
And adjust the toe in as directed in the FSM so it steers nice and straight with minimal steering effort. You will be glad you did first time you drive it out the door.
Nothing better than to mount a "restored " Cub and have it steer as it did when new, nice 'n' tight like a German virgin.
So Far so good!
Old 08-04-2018, 02:22 PM
So Far so good!
What do you mean by tighten up the front axle C channel?
I didn't plan on replacing the tie rod ends, pivot pin, or bushings, but I will now.
I was already planning on going through the steering box.
Old 08-04-2018, 04:06 PM
It's the channel that the front axle pivots in.
Grab the axle by the end, try to twist it like it was a bolt.
Then try to move it frontwards and backwards horizontally.
If it moves fore and aft with a lot of slop, it needs some attention.
Newer GTs have an adjustment to control this issue.
Old 08-04-2018, 04:12 PM
Thanks! I will check that.
Old 09-10-2018, 06:14 PM
I got most of the white parts painted today.
Old 09-10-2018, 06:51 PM
Dstein16's Avatar
Dstein16 Dstein16 is offline
I love seeing these restoration threads. Keeps me motivated to finish projects of my own. Thanks for sharing!
-Derek
Cub Models: Original, 100 (x3), 1282, 1572, XT1 LT46
Old 09-11-2018, 10:42 AM
The new white is looking good!
Old 09-11-2018, 10:50 AM
DieselDoctor's Avatar
Beautiful! Don't you just love the looks of freshly painted parts?
