Go Back   Only Cub Cadets > Off Topic > Gardens, Lawns and Landscapes
Old 06-27-2018, 11:43 AM
bllwnkl's Avatar
bllwnkl bllwnkl is offline
On another note, grading a driveway regularly also helps control weeds.
I have some angle iron and cement blocks and thought about making something like this.
Randy
1976 IH Cub Cadet 1250, 1978 IH Cub Cadet 1250 W/Hydraulic lift
Old 06-27-2018, 11:57 AM
cooperino's Avatar
Might be harder to build but something like this would do a better job I think.
https://www.northerntool.com/shop/to...hoCazYQAvD_BwE
Old 06-27-2018, 12:07 PM
bllwnkl's Avatar
Originally Posted by cooperino View Post
Well. If it helps, heres the torch I use on all my patios and my brick walkway. I just burn em all then sweep or blow them away. I only have to do it once per year and its instant gratification. No waiting for chemicals to soak in.
https://www.northerntool.com/shop/to...RoCSXUQAvD_BwE
Or maybe this!
Randy
Old 06-27-2018, 12:18 PM
cooperino's Avatar
Or maybe this!
Actually the flame is a lot more controlled than that LOL.
Old 06-27-2018, 12:23 PM
cooperino's Avatar
And if you want to do a large area!! lol
Old 06-27-2018, 12:45 PM
My grandad switched the farm to organic in the 90's. Not only have I ran one of those, I built the one we used. Ours was a 6 row.
Old 06-27-2018, 01:11 PM
cooperino's Avatar
That's some HEAT !. Works great right
Old 06-27-2018, 01:19 PM
Yeah, it sucked running it on a 98°day on a cab less tractor. Loud too. Like a jet. Not like deafening.... but loud.
It did a job. It's like like you burned the weeds to ashes. Just got them hot. They would either die, or it would stunt them long enough for the crop to get ahead of them. Problem is, it did the same to the crop. Corn would turn yellow sometimes. Beans, just slowed their growth. Soybeans are very residual, and can take a hard beating and pull through. Corn is in the grass family. It doesn't like having to work hard to grow. Did it work? It helped, but I'm not convinced it didn't cause yield to really suffer. We did good to get 50 bushel beans and 125 bushel corn.
Since it is so wet here, I'm thinking of doing it in the garden. Nothing but a wet sponge. Gotta do something with the weeds. I have one of those handhelds you have. Going to use it.
Old 06-27-2018, 02:08 PM
cooperino's Avatar
Yeah. Like I said. Works great on patio and brick walk. I can burn to root and until black and then sweep away. One time I got a little close to the new black mulch tho lol.. GET THE HOSE!! GET THE HOSE!!! SO now I do it before the fresh mulch goes down.
Old 10-03-2018, 12:10 PM
bllwnkl's Avatar
I bought some weed killer that is 43% glyphosate and the directions say to mix 7.4 oz in 1 to 10 gallons of water. I want to spray my gravel driveway, what would you recommend as the best ratio? Obviously if I mixed it in 10 gallons it would be 10 times weaker compared to mixing it in one gallon. The directions also states that you can mix 6 oz in 1 gallon for spot spraying. I will be using a 4-gallon backpack sprayer.
Randy
