Old 08-05-2018, 10:42 PM
How do you know you got it flat within .1 MM?
No reason it shouldn't be perfectly flat. I mean, .1mm is .04". That's terrible. It won't hold a head gasket with that much warpage. I don't recall the spec, but it's likely only about .001"-.002". If you can't sand it any flatter than that, yeah, take it to a shop.
Check the deck on the block too and make sure it's flat.
Old 08-06-2018, 06:06 PM
682ch23s 682ch23s is offline
Kohler head gasket kit instructions give .1mm spec (.004") with a feeler gauge on plate glass or other suitable surface (as a go-nogo indicator), so that's what I used. Looking at the service manual, .004" is for the next size up motor (25), the 23 is .003in. Might be slightly out of spec.
Old 08-06-2018, 06:43 PM
Time you get done dinking around with a problem engine, you could put Sam's
good used CORRECT engine in there and not ever worry about
ay- dapter parts,bending pushin rods or rockin' arms again.
Old 08-07-2018, 10:07 AM
mickb72 mickb72 is offline
I was really thinking about getting that engine and meeting Sam. I'm taking a trip to TN next week. Between me and a friend i'm sure we could find a place for it. I see it's been sold. Mike
Old 09-30-2018, 05:27 PM
After I few successful mowings, I made it a quarter lap around the back yard yesterday when the Command started running very poorly, making a metallic tapping noise, and slobbering oil out of the cylinder opposite the one that normally drools. Barely made it back. Started OK today, but burning lots of oil. So the Command is going in the shed next to the original KT17 and for better or for worse, I've ordered a Predator 420cc HEMI plus some "stage 1" hop-up parts. I'll post details here as that swap progresses.
