Old 07-21-2018, 09:50 AM
Dirty Steve's Avatar
Got at things early this morning. Put a little JB weld original on the PTO coil cracks. Just cuz. New seal and springs for the governor. Now at soccer practice with the kids.
Old 07-21-2018, 07:50 PM
Governor work did not smooth it out like I hoped. Running rough and kind of rich. On to the carburetor.
Old 07-22-2018, 12:01 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Nice Work Steve!!
Jay
Proud owner of the following:
Old 07-23-2018, 09:03 PM
titleist1 titleist1 is offline
Looking good Steve! Have you cleaned the contacts in the distributor cap? The FIL's had a distinct 'miss' that has been fixed after I cleaned the corrosion off the contacts in the cap. Plug #3 contact in the cap was very corroded compared to the other two so I'm going with that being the cause. Although I can't say 100% for sure that is what did it because I also cleaned the carb while I had it off to get access to the dist cap.
Old 07-23-2018, 09:49 PM
Interesting advice. I have never opened the distributor on one of these. I have not had another chance to mess with again. I had it running smooth at various RPM's. The flutter occurers when accelerating or decelerating. Still leads me to believe it's fuel. New fuel filter before the pump and all new lines to pump then the carb. Lines are showing their age. Great flow coming from tank though. There is wear on the governor arm and throttle control arm at the spring sites. Groove/ notches in both. I assume from vibration of loose spring. Only 9xx hours on this one.
I have not put the tester to any electric components but I did fix the loose negative cable clamp at the battery. Was only holding on by one strand of the twisted cable.
Old 07-24-2018, 03:26 PM
If yours is running smooth at all rpms i wouldn't go messing with the distributor cap.... Unless you still have the carb off you might as well access the cap & check it out & wipe it down (I think its also buried there on the wg600 too?) The FIL's now has a wg750 (donor engine after his wg600 crank was ruined) that had a definite miss that seemed to get worse as it heated up. I believe getting rid of the corrosion on the cap contacts fixed that specific issue.
His also had a couple fuel issues but new bung's & strainers, fuel filters, fuel pump & lines got the fuel flowing again and then disabling the fuel solenoid fixed the stalling issue. His seems to be running strong again but I'd like to take the time this winter to rewire it in the simpler sam mac way.
If your carb is still apart can you please take a close up of the float & valve? it looks different than the FIL's and I'm curious...thx.
Old 07-24-2018, 03:40 PM
Terry C's Avatar
Terry C Terry C is offline
Put an extra twist on the spring. Mine would vary a little till I did that.
It removes the harmonics in the spring. This was mostly for a stable speed not on accell or decell.
Terry
O,100,72,102,123,104,124,105
125,129,149,1200,982
(2)2182s w/60in Habans
3225
Old 07-24-2018, 03:52 PM
Carb is back on it. I'll take a close up pic of the slight wear on the governor arm and throttle control arms. I have an idea on temporary/permanent "gap filler". I starts easy and idles good. Just throttling up or down causes it to load up a tad then it smooths out. I was adjusting the one screw and making gains but can't fine tune it out.
Old 07-24-2018, 04:57 PM
Terry C's Avatar
I believe the screw is idle only. The top end is fixed. Somebody will correct me if I’m wrong.
Terry
3225
Old 07-24-2018, 07:46 PM
Never had one with spring holes so worn.
