Old 08-19-2018, 08:29 PM
hyperlightboards48 hyperlightboards48 is offline
*How can you go forward to reverse without moving the dash lever to one side? In the neutral position, the dash lever should prevent movement to either forward or reverse as it should hit the square "neutral" section?
I’m also curious about this. I tried to wrap my head around this on my 1450 but aside from cutting the dash apart I didn’t know how to make it a fluid motion from forward to reverse, as you have to pull it right or left.
Looks good! I also look forward to the YouTube!
Tanner
Old 08-23-2018, 08:53 PM
Ikea6e Ikea6e is offline
If you added a Foot Control (with spring loaded RTN) to your older cub you may find your foot will get tired on long runs.
If you retained the hand control lever, you can add a "Cheap Guy Cruise Control" and give your foot a rest.
Piece of pickup bed liner, notched at your favorite cruise speed, works well.
Flip it on and off. Panic stop with the Left pedal will disengage it.
Enjoy,
Ike
Old 08-23-2018, 10:46 PM
Ike, if the dash lever has a lock with a notch cut in it to hold the lever, how would it return to neutral with the foot lever? It would be locked on the dash....
Why would your foot grow any more tired with a RTC spring over any other foot controlled hydro??
Old 08-24-2018, 02:44 PM
Since the 'Cheap Guy Cruise Control" is made out of soft bed liner material the Foot Lever easily over comes it, (normally I would just depress the foot control slightly and push it aside.
Different linkage geometry than OEM, perhaps the age of the driver, bad disk in the back, etc. may have something to do with it. ;-)
Plus, sometimes a guy does something to these machines just to see if it works. Like the light on my dash that comes on when the mower deck is up.
Take Care,
Ike
