#41
I would continue with this Jon, But I have a company to run here and right now your bringing only drama to the table.
#42
Several have offered tests and possible solutions. Now we should sit back and let the OP discuss his actions and outcomes.
![]() Queen Of The Quietlines! ![]() |
#43
![]() Quote:
Daddy always said lube is good for things that move ![]() Don't whittle toward yerself Don't pee into the wind. Do drink up stream from the herd. |
#44
I agree Beth, time for the OP poster to test things and get back with us.
#45
Oh, The OP did use oil. And it worked, For now. I just can't see doing this every couple months. The originals did not need it every couple months. Leads me to believe there was another underlying issue is all. Hey for a quick fix I guess its ok.. Like I needed to cut the grass 2 weeks ago kind of fix. I am just not into short term fixes. I mean if the bendix gets stuck that easily why not pull it apart and trim a couple thousandths off the shaft? CLean up the engagement points.
#46
Kohler makes a lube for the helix on the shaft, I have some.
I can provide pix if necessary. it is the consistency of lubriplate white grease. They caution to apply lightly. That said, Collected dust/dirt in real life impedes the sliding motion as it collects on the helix/worm. In colder weather, below freezing. it is more problematic. Now this is just some old man's findings and not meant to be a rebuttal or argumentative. When I get one that likes to stick (M-18's) it gets a shot of garage door lube or what ever lube I have handy----till next time. |
#47
#48
![]() ![]() We are out of popcorn!
#49
This site needs a "nether" region or even a sewer section for when topics deteriorate to this level.
Then you guys can take your pissing matches there. |
#50
11 volts at Starter. Forgot to choke, then 11 dropped to 10.8 and started. 14.2 while running at starter. Because the outfit I bought the starters from told me to just keep the previous starter (presumed defective) I look forward to putting a little oil on that one, and installing it to see what happens. I'll post results
