Old 10-16-2018, 09:29 PM
John147 John147 is offline
Originally Posted by nophun View Post
Sounds like the governor is out of adjustment or sticking, It looks like there's a bit of rust in the pics, something may hanging up.
I read the procedure on how to adjust the govener I’ll give that a shot and see can’t hurt at least lol.
Old 10-18-2018, 07:55 PM
Well some bad new the Governor gear is shot. Adjusted to the way the kohler repair manual wants and it just wants to take off i just cut the ignition and closed the throttle by hand. I picked up a 551 blower today so now i am kinda committed to this machine.
Old 10-18-2018, 08:20 PM
nophun nophun is offline
Don't write it off yet. When I first got my 2185 running I had to do all of the adjustment several times due to PO "adjusting" things. I ran into the same thing that you just described which was solved by readjusting the throttle cable.
Just to be sure: you adjusted the governor counter clockwise wile holding the throttle lever at carb against the stop (wot) and re tightened it this way?
Old 10-18-2018, 09:01 PM
Yes sir i even adjusted to three time to make sure i didn't mess up i printed the page and kept re reading it. If i feel the gov lever when it starts it doesn't even attempt to pull the throttle close it just goes WOT and stays even it the throttle is the idle position. I'm gonna pull the back plate off tomorrow and inspect the gear.
Old 10-18-2018, 09:33 PM
Here some pictures of my new nose and the current state of my poor 1864.
Old 10-18-2018, 10:10 PM
Hopefully you did not pay a lot for the 1864.
Up to 534 and counting...
Old 10-19-2018, 06:42 AM
More then I probably should have I’m sure, Thats what happens when you buy on want and not logic.
Old 10-20-2018, 06:10 PM
Turns out i am a dummy and adjusted the Governor wrong i re adjusted and all is well thankfully. I finished making my tractor look whole and installing led lights.
Old 10-20-2018, 06:12 PM
I need to replace the PTO and my tractor has the older style, Can i upgrade to the newer style as they are cheaper?
Old 10-20-2018, 06:27 PM
Yep, check out Xtreme. Link in the parts area.
https://www.onlycubcadets.net/forum/...ad.php?t=45466
