Old 11-05-2019, 08:11 AM
Is that a model 190-308-100 tiller? There were only 3 models made by Cub Cadet to fit the SGT's. The 308, 442 & 356. I don't have a 308 so I'm not sure that is what you have but it looks like one. If it is, it was made by Befco. Here is a link to the parts manual.
https://cdnmedia.endeavorsuite.com/i...%2005-2010.pdf
Messick's also has some parts available.
https://www.messicks.com/bef/6360
Let us know how you make out. A lot of people have been looking for replacement Cat 0, 2000 RPM shafts with no luck over the years.
Old 11-05-2019, 01:23 PM
frankpagliai frankpagliai is offline
Default might of gotten lucky...
Oak,
I came across tractorpartsasap.com when doing a search for the yokeshaft late last night and emailed them. They replied back to me this morning that they had one nos. I ordered it, will have to wait and see if it ships. I tried to find out who the previous owner picked it up from, be he can't remember. Worse case scenario, I can whittle a dowel rod down to make an adapter.
1969 106 Cub Cadet
1980 982 w/ 3pt-pto, 60" haban deck, 54" power blade
1981 382 lawn tractor
1968 B110 w/ 42" deck
Old 11-06-2019, 09:59 PM
Default 308 tiller and 54" blade both mounted
I mounted the tiller tonight.The pto yokeshaft is supposed to be here Friday. I put a bolt through the undercarriage for the haban blade to attach the lift arm so that I don't have to remove it when I am not using it. Guess I could leave the blade on the front for a counter weight when tilling.
1969 106 Cub Cadet
Old 11-06-2019, 11:26 PM
I stumbled upon this while searching.
https://store.germanbliss.com/befco-...42-542-150-550
It is for the 2000 rpm version of this.
http://www.befco.com/images/PDFs/Par...%2011-2016.pdf
Keep us posted on the progress.
Old 11-08-2019, 05:30 PM
Default tiller update
Oak,
It was a model 308 made by befco. The yokeshaft came in and I got it installed last night. It appeared that the tines were moving faster than they should, but I tried it out in a spot in the yard and the tractor handled it fine. I won't know until I take the chain cover off and see the gear size. For the 2000 rpm it is supposed to be 9/22 and the basic 540 is 15/16. At least it is working so far and I have a little time before I will have a chance to use it much...unfortunately.
1969 106 Cub Cadet
Old 05-11-2020, 09:46 AM
Default new kicks on the front
Just installed some new tri-ribs from Miller. They are pricey, but I am sure they will never wear out. And it does steer nicely.
1969 106 Cub Cadet
