Old 04-04-2020, 09:25 PM
GERKS 149 GERKS 149 is offline
My starter generator was in similar condition to yours and I found a nice rebuilt unit for $77 on EBay. There is one left at that price. Couldn’t even come close to getting mine done for that price. The pieces and parts would have been more than that. Here’s the link:
https://www.ebay.com/itm/1963-74-INT...gAAOSw5KBck7T9
Old 04-04-2020, 09:46 PM
Vrobert's Avatar
Vrobert Vrobert is offline
Let us know how it works for you. I bought one from DB Electrical for $100 that seems OK. I posted the details earlier in this thread.
Rusty 149 project with:
QA42 snow thrower
38" deck
Barn fresh 1811 with:
44c mowing deck
QA42A snow thrower
42" snow blade
Old 04-06-2020, 05:40 AM
Steveshow Steveshow is offline
I have a 1973 128 that my uncle bought new. Shes pretty rough but managed to till the garden twice now for me. I experienced the same issues with an ebay carb recently. I saw your post on the 149 and I am envious. I found a used creeper box and spring lift assist for the 128 but thought i would try and find a hydro tractor with lift like your 149. I found one not too far from me on facebook, but no response for two weeks now. Its for a running working 149 with mower for $250 (!) Even more frustrating is the fact that the seller recently lowered the price from $300...��
Old 04-16-2020, 10:50 PM
Vrobert's Avatar
Default 149 steering mount cross member
As I have mentioned, the 149 steering box cross member flexes significantly, in fact, my cross member was cracked at the mounting bolt and the weld to the frame. I did a crappy weld job on it but it still flexed, so I cut a piece of 3/16" x 1.5" x 10.25" bar stock to weld on to the existing cross member. Because the Ross box mount is slightly angled I ground a piece of bar stock into a wedge shape with a Norton Blaze wheel (they cut like butter).
I'd like to say I welded it on and the Ross box is rock solid now. I did, but it's not. My mig welding skills suck especially badly when I'm laying on my back with bad lighting. It looks like a disaster but it's more solid than it was. If I'm feeling brave I'll snap a pic tomorrow just for a laugh. I need a good laugh. I'll redo the welds the next time I decide to remove everything from the frame and can flip it upside-down, in other words, probably never.
It's OK though. I only spent 2 days on this little project to be ready for moving snow next winter. Did I mention that it didn't snow once in Annapolis last year? I guess it's good insurance, if nothing else.
QA42 snow thrower
38" deck
44c mowing deck
QA42A snow thrower
42" snow blade
Old 06-08-2020, 05:45 PM
fried fried is offline
Great project. Thanks for sharing pics and I'm also glad to hear the option for getting tail-lights. I have a long way to go to get up and running but I'm steady moving towards it.
Cub Cadet 149
Cub 1882
Cub Cadet 126
Yanmar YM2500
Old 06-19-2020, 05:23 PM
Vrobert's Avatar
Default drive shaft refresh
The saga continues.
I noticed two things on my cub. A knocking sound that occurs when I move into neutral, and a badly notched engine to driveshaft coupler. Thinking they might be related, I decided to weld up the notches, replace the fan, and, paint the shaft and coupler. My question is; should the shaft to rag joint be square? If the driveline isn't perfectly straight, it shouldn't matter if it's a little off of square because the rag will be flexing anyway.
Should I get the welder out or just slap it back together?
Look at the pics....
BTW copper pipe perfectly fits the coupler for welding.
QA42 snow thrower
38" deck
44c mowing deck
QA42A snow thrower
42" snow blade
Old 06-19-2020, 05:47 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Sure, it should be pretty square +/- a rag joint flex or two. Given that it doesn't turn at 30000 RPM, you should be able to get that one pretty close with some judicious bending (bolt flange down, and put pipe over the shaft part, almost the whole way down).
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 06-19-2020, 06:04 PM
Vrobert's Avatar
Heck, I just realized that I have shim washers I can add on one side. Good enough for this old thumper!
QA42 snow thrower
38" deck
44c mowing deck
QA42A snow thrower
42" snow blade
Old 06-19-2020, 08:15 PM
TomRom's Avatar
TomRom TomRom is offline
Originally Posted by Vrobert View Post
The saga continues.
I vote you get the welder out.
By the way nice trick with the copper pipe, please post a pic if do weld it up.
IHCC - 122, 125 x2, 127, 108 x2, 129, 149 x2, 1200, 1250, 1650 x2. SEARS - Six Speed Suburban 10HP, Quick Speed Change Suburban 10HP, Six Speed GT18 Twin. ECONOMY - Country Squire. CASE - 580B CK tlb. That's it for the 4 wheel ones....
Old 06-19-2020, 09:07 PM
Vrobert's Avatar
I welded the notches in the coupler but I will never allow human eyes to see my welding until I clean it up with abrasives. It looks ok now.
The rag end of the shaft was perfect after I added a shim washer so I just bolted it up instead of rewelding it.
Bummer though, it sounds like I have a 'knock' but I'm not sure.
QA42 snow thrower
38" deck
44c mowing deck
QA42A snow thrower
42" snow blade
