#41
I'm not sure. I typed in k301 carburetor on Ebay and bought the 1st one. I put my original carb back in. Seem to start up better but still have a little long cranks but runs smoother.
#42
Any chance you can post a video of starting on YouTube then post link here?
#43
I dont have you tube account but I have facebook where I can send the video to?
#44
Another thing to cross my mind, what about spark plug gap issue? I have it set at .025 per manual. Should I try increase it or close it? I'm running Champion plug. I have a printed service manual from IH.
#45
.025 is fine
#46
The IH manual is wrong if it says .025 for battery ingition systems.
Project Uncle Dick Cub Cadet 70 http://www.onlycubcadets.net/forum/s...ght=Uncle+Dick |
#47
I'll have to double check my manual. I might have read it wrong. What is the part number for the auto lite spark plug? I'd like to buy it local tomorrow.
#48
Merk is correct. Tuned my 1211 most recent. Its a Mag. Must have got .025 in my head from that.
#49
So, I gotta run .035 gap. Changing brand of plug might solve my issue. I hope.
#50
I've only got 65 + years experience fooling with engines,
so take this with a grain of salt. Been my findings that a gap of .025-.035 and any manufacture of plug will work in a good engine. if it is worn out, or other problems, it will be because of something other than the gap or the manufacture of plug,--- within reason. If an engine is oil fouling them, go hotter to get you by. if a weak ign system, a closer gap might get you by. Points rarely "wear out" but they do pit or become corroded/dirty. setting points near .020 will get you running. static method gets you closer. A bad condenser will usually idle fine, but not rev up. of course if it is shorted, you will not have spark. hope this helps. I have gotten bad "new parts" and it bit me in the ass every time. Assume nothing. |
