Old 05-11-2022, 09:28 AM
1711Cub's Avatar
1711Cub 1711Cub is offline
Lightbulb
Verified that the IH-61176-C92 pulley is an acceptable replacement for the original 756-3032 fan idler pulley, which has been discontinued by MTD, for some time. The pulley is virtually identical to the original except that the IH part has a slightly deeper belt groove.
582, 682, 782, 782D, 1282, 1050, 1210 x 2, 1711, and 1811
Old 05-15-2022, 04:40 PM
Nice work on the 782D!
Old 05-15-2022, 05:28 PM
1711Cub's Avatar
Thumbs up
Thank you. More to come..
Old 06-06-2022, 08:03 PM
1711Cub's Avatar
Cool
Adding the missing pieces to the puzzle. Located a new Kubota oil fill tube and injector tube retainer brackets. Next addition is a battery master disconnect switch.
Old 06-06-2022, 09:54 PM
Farmall450's Avatar
Interesting filter on the breather. Does it puff much?
Old 06-07-2022, 07:33 AM
1711Cub's Avatar
Smile
No, no puffing. A previous owner added it instead of the draft tube. I might switch it back since I am going for mostly factory originality here.
Old 06-08-2022, 09:15 PM
1711Cub's Avatar
Thumbs up
Refinished the grille
Old 06-11-2022, 07:49 AM
1711Cub's Avatar
Thumbs up
Master battery switch installed..
Old 07-03-2022, 07:06 PM
1711Cub's Avatar
Thumbs up
Repainted the seat base and engine side cover with Irongard enamel.
Old 07-09-2022, 04:38 PM
Your 782D is looking great!
