Old 01-31-2026, 11:03 PM
Ambush Ambush is offline
If the knuckle is going to bend, it will be just above the stub because of the leverage applied there by weight on the tires. These hadn’t bent yet and I doubt they ever will, but I figured I might as well give it a bit of spine anyway. And it will help prevent warpage when I weld the stubs in.
Old 01-31-2026, 11:06 PM
Time to fill and drill the pivot holes, after I sketch out the hole layout.
Old 01-31-2026, 11:15 PM
I clamped the ears to a heavy copper plate, spaced up about 1/8” for full
weld fill. The metal should be hot when you start and filled in one shot, leaving it orange hot. This will make sure there are no hard spots in the transition zone. Let it cool slowly. I only did one hole per knuckle to start so I’d have a flat spot to bolt it to the table for drilling square to the axis.
Then most of the weld got ground off and the new hole location scribed and punched as per the sketch
Old 01-31-2026, 11:20 PM
Then clamped to the table and drilled, first a pilot hole than the 1/2” bolt size. Then repeat the process for the other side.
Old 01-31-2026, 11:24 PM
Next I machined a spigot on the stub and left a shoulder to keep it square the plate. Some preheat and some weld.
Old 01-31-2026, 11:28 PM
Just some clean up and paint now. I’ll swap the ag tires onto those rims sometime next week.
Old 02-02-2026, 08:07 PM
So the axle and hub upgrade is done and paint is drying. I took the tires off the new rims and wrestled the ags tires on to them. Man they are a bear!!
Before seating the beads, I got out the handy dandy Sawsall powered, rattle can rattler and shot some paint on the rims and freshened up the hubs. I’ll do the other sides tomorrow. I think the paint is hard enough on the hydraulic lines that I can start installing them too.
Old 02-03-2026, 09:08 PM
The tube maze is done, with not too much consternation. I just have to pickup two quick couplers and make a bracket for them.
The axles and hubs are installed and waiting for the paint to harden on the rims. Fixed a few loose things on the dash and tower. I have a few things planned but not sure what order I’ll do them in yet. See what moves me in the morning
Old 02-04-2026, 11:11 AM
Ambush, you are doing a fine job on this mod. Keep up the great work and keep feeding us pics. I've really enjoyed this post.
Old 02-04-2026, 02:08 PM
ironman's Avatar
ironman ironman is offline
Me too. I cant wait until he gets to the power steering.
