			#5091
			Today was a work day with the cubs... the 123 did mower duty (I need to get some new blades) and Dukes favorite multi colored O did sweeper duty.   :-)
			Hot out there today... but at least it was humid! John
			#5092
			Looks good guys!
			I mowed alittle with and the 48 inch mower I bought off of Mike but it is hard to mow with no throttle cable because i forgot to get one off him lol I'm happy with the mower i little it better than the little 38 inch.
	1971 128,3pt,ags,rebuilt motor,headlights 1988 1812,dual ports 1966 122,creeper,3pt,ags,sa,headlights,restored 1st place at RPRU 2013 1966 123,3pt,brinly spring assist 1973 108 1968 125 Attachments:QA36A,wfblade,2 nf blades,brinly disc,a cultivator,plow,homemade wrecker boom with 2000lbs winch,ih weights,50lbs weights,2IH windbreakers  |
			#5093
			Jenn mowed with the 2130.  I got some seat time on the 1872 using the lawn sweeper.
	Allen Proud owner of my Original and 126! My Grandpa's Cart Craftsman Lawn Sweeper Craftsman Plug Aerator  |
			#5094
			I got some parts primed for the 149. Frame, rear end, front axle, spindles, & front wheels.
			Made some new bearing races for the 100's steering box and got it reassembled. I rebuilt the steering box in '08 with new bearings and races. The new races I bought were hardened whereas the original ones were not. The new ones were too hard and brittle and they crumbled to pieces making the steering bind. The set I made are thicker and made of 4140 PHT material which should outlast the rest of the tractor.
	Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone  |
			#5095
			Looks like it's going to be a nice day.  Maybe, we can finally get the wheel weights on the 1872.
			#5096
			my girlfriends step dad called me to tell me the cub cadet 1200 i put together for him had just died in his yard and now has no compression...which made me start thinking something internally had broken. i got the tractor back to my place, tore the side panels off and noticed the air cleaner box was loose...so i paid no attention to it and took all the tin work, gas tank and firewall off. pulled the head. i cranked it over and the piston was moving which was a huge relief....but the intake valve was not. one of the screws that holds the air cleaner backing plate on got sucked into the engine and lodged in the intake valve. LUCKY it didn't get anywhere else...i took the carb off to get to the screw and the other bolt fell out of the carb. got the screw out and the valve seems to work fine. it has tons of compression still and fired right up with the vapors of gas left in the carb when i put it back on. before i bring it back to him, im going to locktite those bolts holding the air cleaner backing plate on. lesson learned.
			#5097
			Killed grass with the 2284 and 60" deck. No drama just a nice enjoyable day.
	2264 with 54 GT deck 1641 AKA Black Jack with a 402-E Haban Sickle bar mower JD317 dump truck BX2670 with FEL  |
			#5098
			Got my footrest pads, wheel weights and new gas cap on the 1872.  Here's some pics.
			#5099
			The super is coming along nicely Allen! Looking good!
			#5100
			Nice work ACecil
