Old 11-25-2018, 07:17 PM
chris hall's Avatar
chris hall chris hall is offline
I mowed leaves for about two hours. I think I will be getting a Cyclone Rack next year. I am thankful to have a bigger tractor then last year.
105(sold)782x3 &124(sold) . Lawn sweeper yard cart. Homemade 3 point hitch narrow frame sleeve hitch spring assist ih snowplows . Rear weight bracket and suitcase weights.Lots of extra parts 😀.
Old 11-26-2018, 11:53 AM
Wrapped up the snow bucket project I started earlier this month.
Awesome job!
Old 11-30-2018, 08:50 PM
SLS327 SLS327 is offline
I took the mower deck off my 127 and put on the blade. I put the chains on too. Still running 30wt oil and goin to change that to 10w-30 over the weekend.
Steven
__________________________________________
127 NF, spring assist, 36" IH Danco BB-36 snowthrower, 42" mower deck. CW-36 snowthrower, 42" NF blade. QA42A blower, 126,127,149,1720.
Old 12-02-2018, 01:25 PM
twoton twoton is offline
Pulled the motor from the 1200.
Old 12-06-2018, 04:57 PM
Split a 100 today to remove the creeper and fix the backward shifter thingy.
Got lucky on the creeper shaft. Not so on the steering wheel...
Up to 534 and counting...
Old 12-06-2018, 05:37 PM
cooperino's Avatar
Are you parting that one.
Old 12-06-2018, 05:49 PM
No, I am putting it back together minus the cweepy gear.
The steering wheel came like that when I got it 2 years ago...
Old 12-06-2018, 06:01 PM
Garyoh5a Garyoh5a is offline
Default AC generator installed on 1650 Cu
Mounted a 3500w generator to front of my 1650 and cut junk trees with an electric pole chain saw.
Worked great, now thinking if painting the generator Cub Yellow to match the GT
Old 12-06-2018, 06:45 PM
What type is the electric maker, I see northern tool has heads, just add a pulley.
Do you have any photographs of this?
Old 12-06-2018, 07:41 PM
cooperino's Avatar
Pincor made them for Cub cadet and other brands.. They were orange. I built my own from a homelite gen set.
Heres a picture of the Pincor model
And the link to the one I built and showed here.. I need to update that also.
https://www.onlycubcadets.net/forum/...ad.php?t=53062
