Old 02-05-2019, 09:36 AM
Fabbed up a weight box for the rear of the 1650 I just resurrected.
Using mat's I had laying around, it weighs 35 # empty and hangs on the lower 3 point and upper lift bar frame mount holes.
Shown mounted, w/35 #'s of weights
Old 02-05-2019, 12:20 PM
Nice job on the weight box!
Old 02-05-2019, 01:49 PM
cheesedawg82's Avatar
cheesedawg82 cheesedawg82 is offline
Looks good!
PO put a similar weight box on my 106 made from aluminum in 1971 and it's still holding up. I put a 5 gallon bucket back there, which holds a full bag of cement at 50 lbs, and made all the difference in the world plowing and climbing hills in wet weather.
Grumpy old 149/1A tiller, Trusty Rusty 106, & a Massey Ferguson 10 to work the garden, Tiny Snapper to mow the lawn. Slowly accumulating attachments and quickly driving the neighbors crazy on a half acre homestead.
Old 02-05-2019, 01:51 PM
ColoradoCadet's Avatar
ColoradoCadet ColoradoCadet is offline
Thanks Woodtrucker, that is much less than half price from the Firestones. Those Deestones are thinner so I think that is more of the look I am going for too. Thanks for the input. BTW - I like the black wheels too.
Wayne
Old 02-11-2019, 11:58 PM
JPWright JPWright is offline
Default The 100 gets a new wire
I have been having difficulty with the 100. It sputters and pops a lot. At first I thought carb and decided to readjust it. After plowing the driveway the problem persisted. I then I cleaned and adjusted the points. It seemed to work fine but not great for the first snow plowing of the season. Second plowing yesterday and the problem was back.
When I started it, the spark seemed to be irregular at the points so I thought bad points and replaced them. I put in new points and a condenser and got it running. As I looked at the spark with the point cover off, I noticed that it was still not regular. A misfire would occur quit often. I checked the ignition wiring to and from the coil.
I discovered that the wire from the coil to the points had hard insulation and some cracks where the bare wire could be seen. I replaced that wire and the 100 runs fine again and I have some extra points and a condenser.
I hauled in some wood before the storm.
A 122 with weights and a deck for mowing trails.
100 with loaded ags, three point for ground engaging brinly cultivator, brinly disc, thatcher, cart and snow plowing.
100 with weights for wood hauling.
Rusty functional 102 with rear lift.
Elec Trac E15 for finish mowing.
Old 02-12-2019, 12:09 PM
Nice 100, glad you got it going!
Old 02-14-2019, 12:51 AM
johncub7172's Avatar
Attachment 98331
Yea that's a good find. A lot of times, the crack will be hiding under the wire suspension clip that's fastened to the cam cover bolt ( if its still there ).
Old 02-14-2019, 09:20 PM
Default wire break
That is exactly where it happened.
Old 02-18-2019, 07:54 PM
Kjamesm's Avatar
Kjamesm Kjamesm is offline
Decided to put chains on the 128....regret not doing it sooner!
Old 02-19-2019, 11:11 AM
SJones SJones is offline
I rebuilt the deck. Rebuilt the bearings. then cleaned and repainted it. It has a season on it now and it is in good shape with the paint holding up well. Used an epoxy paint with a color called biscuit which was a pretty close white color. That was a test for doing that to the rest of the 126. It is from 1971 and needs a good repaint. right now the clutch is getting needed cleaning and lubricating.
