Old 12-04-2012, 03:50 PM
Sam, I believe it could be the check valves.
Well if that is what is leaking that is an easy fix
Jenn and I also discovered the steering column is also leaking.
This is a bit more involved, holler if you need help.
Old 12-04-2012, 06:41 PM
cub123's Avatar
cub123 cub123 is offline
Worked on the shop a little today, should be ready to pull the rear out tomorrow
Old 12-04-2012, 07:54 PM
Hey Ben
What is the dirt bike off to the right?
Old 12-04-2012, 08:02 PM
cub123's Avatar
Hey Ben
My WR 250f, but with the amount of work I've done on it, it's more like a electric start YZ250f.
Old 12-04-2012, 10:09 PM
Jenn and I found the leak on the 1872. Glad it's an easy fix.
Old 12-04-2012, 11:52 PM
Jenn and I found the leak on the 1872. Glad it's an easy fix for Jenn and I.
Awesome news buddy! Those went from good to bad quick.
Old 12-05-2012, 06:12 AM
Good to hear you found the leak Allen and an easy fix!
Old 12-05-2012, 07:02 AM
Nice work Jenn!
Old 12-05-2012, 01:12 PM
Thanks guys!
Old 12-08-2012, 06:51 PM
Did a PTO swap on the 1210/1640 today. The 1210’s had a 4.5” pulley on the PTO and the Vanguard 16 I put in that came out of a 2160 had a 6” pulley. Worked out to about a 30% overdrive. Before I roasted the bearings in the mower I thought it would be smart to put the correct size PTO on it. Had to get a mounting plate machined to accept the PTO from the old Mag 12 and a bushing for the ID on the PTO. The Kohler has a 1.125” shaft and the Vanguard has a 1” shaft. Sort of a PITA but it’s done and works as it should.
