#51
I started it up today after sitting since Sunday and not one bit of smoke came out the exhaust, looks like it's a keeper.
#52
I ordered the new fuel pump last night and hopefully it's here on Friday cause the wife is off and I can stay late to tinker.
#53
You got the luck on this one! It's a good feeling to save one.
http://www.onlycubcadets.net/forum/s...ad.php?t=42646 70, #1 cart. Brinly Cultivator. Some wheel weights. {125, 126, 2072-Sold~regrettably, 2284 60 inch Haban 325 deck., 451 snowblower, 2182-60 inch Haban 374 deck- "Money Pit", 401 Haban 54 inch dozer blade- rebuilt, 1440-down the road, Another 2182 for parts. Another 2284 for parts. 450 blower. 1812-sold, 2072 w/ Haban 374, and a 2182#3 w/ Haban 325}-------> All SOLD |
#54
Yes, I am very pleased with the outcome so far. If everything goes my way I'm going to pull the rearend this weekend to fix the trunion and replace the fluid/filter and then it will be ready to be put to work. I have some side panels on a junker out back and the same tractor will donate it's seat and mounting plate.
#55
I've enjoyed seeing you save another one. Glad it's working out for you.
#56
Why do you need to pull the rear to fix the trunnion? More wrong with it, other than the out of square hole?
Make the best of each day , Todd Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
#57
The cork gasket isn't leaking so I think I will let that sleeping dog lie. I guess I could fix the trunion in the tractor but it will probably be easier with the rearend out.
#58
I got the trunion repaired today, i did it in the tractor and it was pretty easy. My issue before was it didn't have neutral and that was caused by a previous trunion repair, whoever fixed it before made the hole about a 1/4" shorter than it should be so the trunion was just flopping around inside the other piece. Once that was repaired and i got the linkage adjusted i changed the fluid and filter, i'm still waiting for the fuel pump so i can put the tins back on the engine.
Somebody had a homemade lift kit on the fenders to make them sit higher so they were all bent to sh1t so they got tossed in the dumpster and i got a different set off a parts tractor out back. The side panels were also stolen from a parts tractor but i will probably buy a nicer set when the time comes to paint it, the seat is junk but at least it give me something other than the fender to sit on.
#59
Good work Tim! Love that fancy paint scheme...
Queen Of The Quietlines! |
#60
I think he was listening to Dolly Partons "Coat of Many Colors" on the radio.
