#51
The steering wheel is in decent shape, but it is very loose where the spokes go into the center hub. I'll probably have my brother in law pic up a new repro for it. I thought it looked like Ford blue too, LOL. I have to wait for my nephew to come help me take the engine apart, altho curiosity is killing me. I might at least pop the head and measure then put it back on for him to take off.
DWayne 1973: 128, ag tires, 3pt. lift, spring assist, lights, 42" Deck 10" moldboard plow 2016 XT1 42" deck 18HP |
#52
Looking good Dwayne, I like the breather cover, with a pre bent rubber hose of the right diameter, you can vent down below the motor, keeping the new paint nice and pretty!
Jeff Brookfield, MO ________________ IH Red 782 with weights and sleeve hitch! IH snow blade, Brinly plow, Brinly disk, Brinly harrow, Johnson rear blade, and a #2 IH Cart |
#53
that's a good idea, I was wondering what I was going to do with that vent, LOL.. Thanks
#54
Sweet pics DWayne! After looking at the pic with the wiring the right side was cut narrower then the left side. Just measure where the tabs are welded on the dash tower and use the same width as the base and the same height as the top of the tabs and you'll have everything you need make a new battery box.
#55
Was a nice day out and everyone was gone, so I had some time to play, ahem I mean work on the 73 a bit. First order of the day was the steering wheel removal. I have been spraying it with PB blaster the last few days. I got my air chisel and installed the custom made tool I use to remove the steering wheels with. About 10 minutes of some easy work rotating the wheel while applying upward pressure and using the air chisel the wheel suddenly slid right off. I continued with removing the sead and rear seat mount. Removed the steering tower and removed the clutch assembly. I was also able to get the Engine PTO removed. I had to drill out one set of set screws. They were FUBAR'd pretty bad from PO. You will see the PTO bearing was not installed correctly and the back side of the PTO was rubbing the end of the crankshaft . Some hand filing removed the ridge from the crank shaft. I am going to have to buy a gear puller to get the bearing off. It is on "tight". As you will see from the pic of the motor I pulled the head, there is quite a bit of carbon and I took a picture of the piston at the top and then at the bottom. If you look real good you can see quite a bit of the rings on the Carb side of the cylinder. Egg Shaped, but I am pretty sure .010 will fix it, but will know positively once I get the piston out. That was about all I accomplished today. Oh I did have some time to polish on the 982D out side in the shade before I put it back up.
Air Chisel Tool made by cutting off the head of a 3/8x4" bolt. Tool installed for removal: Success, and no, I have not had any bearing cub or bearing damage removing the steering wheels this way. Nice clean damage free steering shaft and tube: Almost there, just a few more things to remove: Inside of the steering tower after removal:
#56
PTO Bearing installed too far back
Piston and valves and carbon, the head was pretty nasty: Rings showing pretty bad on one side:
#57
Thanks for the pix and a question
Great pictures and it looks like you've got one well worth saving.
On your wheel tool, do I understand that that bol5 slides down inside the steering column shaft and the tool hammers on the shaft with the nuts you have threaded on there? It's a good idea ...air tools...impacts and the like save a lot of bolts/nuts AND knuckles Thanks John |
#58
Awesome pics and updates DWayne! What a great way to spend some free time!
#59
I use the same method to remove the steering wheel,but I loosen the nut a turn or two,and leave it on.Always use a lot of soak time with the PB blaster
#60
looking good Dwayne! Reminds me of me restoring my 73. I was lucky with the motor it sat inside for 16 years and started right up with no smoke! the 73s are neat little cubs. here is a pic after the resto cub pics 002.jpg
1971 128,3pt,ags,rebuilt motor,headlights 1988 1812,dual ports 1966 122,creeper,3pt,ags,sa,headlights,restored 1st place at RPRU 2013 1966 123,3pt,brinly spring assist 1973 108 1968 125 Attachments:QA36A,wfblade,2 nf blades,brinly disc,a cultivator,plow,homemade wrecker boom with 2000lbs winch,ih weights,50lbs weights,2IH windbreakers |
