Old 10-26-2011, 01:28 AM
cubs-n-bxrs's Avatar
Frank1541 the drive shaft is holding up just fine. The drive shaft is as tough as any other drive shaft I have seen. I had it in a plow field puling a 10" plow with no problems. Was snatching out a few saplings a couple weeks ago with it and is still holding. I used a brand new choke cable and just crimped a new cable in the original throttle mechanism which was long enough to reach the control. I am very pleased with how it turned out and on top of that it sounds bad a$$ with the dual exhausts.
Old 10-26-2011, 04:01 PM
Donovan M.'s Avatar
hey kelly would you sell that engine to me.
Donovan:
62' Original-fenders
Old 10-26-2011, 05:54 PM
Donovan refresh my memory. Not sure what engine you are talking about.
Old 10-27-2011, 11:59 AM
Frank1541 Frank1541 is offline
Kelly. Thanks for the reply, its good to hear that the tractor is holding up for you. It looks like you had an older style shaft on the red tractor. Do you know if they are the same diameter as the cyclops drive shafts. Also what diameter pin did you use.
John
Old 10-27-2011, 01:13 PM
Frank as far as the drive shaft is concerned I am not sure about the cyclops shaft. I have a 1641 also and have never taken a close look at it as far as O.D. dimensions are concerned. Yes the 682 had the rag joint style shaft in it. The O.D. of them shafts are 5/8th which is the same as all the gear drive machines also. I used the coiled spring pins used in a gear drive shafts to pin them together. The pin diameter is 1/4in. I will be using the other half of that 2185 drive shaft in my 125 on the flywheel end. Any more questions I will be glad to help. Good luck with your retro fit.
Old 10-27-2011, 06:10 PM
The cyclops has a splined shaft that is 3/4" IIRC. The ideal way to do it would be to machine a sleeve into which each half of the original driveshaft is a press fit, and then cross-drill and install tapered solid pins. I have seen that done before.
Old 10-27-2011, 08:47 PM
Donovan M.'s Avatar
the engine you pulled out of your 682.
Donovan:
