Old 03-28-2012, 11:50 AM
esarvey's Avatar
esarvey esarvey is offline
Default broken promise!!
AH GEE OAK, U promised not to tell !!
The PPM ran well and it did do a good job plowing. What he doesn't show you is the nitrous oxide system hidden in the little red tank on the front of the tractor.
DaDuke of
2145,1864,1811,1810,1541,1330,1210,1020,1641,147,1 24,73, IH FARMALL CUB. 7254, 1863, IH 982
Old 03-28-2012, 04:20 PM
j.m.jackson j.m.jackson is offline
Daduke,
I was behind you on the green machine with the turfs, those ATV tires really had the advantage in that wet clay that turns to pudding, that's for sure. I wasn't sure if I wanted to go with the standard bar lug tires on the green one and the SGT, but I think I'll go the ATV tire route.
--Mike J.
Taylors, SC
1872 - running and mowing!
1882 - in progress
1772 - in pieces, Farmall 200 with a fasthitch 2 point sickle mower, Farmall Super A with cultivators, hillers, middle buster
JD 330 w/3 point, Scag SR-18B on mowing duty
Old 03-28-2012, 04:56 PM
esarvey's Avatar
Thumbs up Thanks Mike
grate time was had by all!!I only told Vinnie but, my hydro rod was maladjusted. and I had only 3/4 speed forward, my governor was wacked and I alwas fought to keep engine from blowing, all day but excusses aside the traction was super with the MUDHOGS, they also are 27" tall gives alittle higher gear ratio, helps in mud,but the massive cleats due the trick! the green machines looked to be dueing a fine job out there, I love to see the small guys duing it, ab/sears/murray,ect. they out there driving their buts off!!! that LADY out there was good with her narrow frame machine also! the pride these guys show in (GITTER DONE!!!) amazed the land owner, every place we all show up, they shake their heads and say never thought they'd do it!!! Thanks agin my BROTHER IN PLOW!!!
Originally Posted by j.m.jackson View Post
Daduke,
I only told Vinnie but, my hydro rod was maladjusted. and I had only 3/4 speed forward, my governor was wacked and I alwas fought to keep engine from blowing, all day but excusses aside the traction was super with the MUDHOGS, they also are 27" tall gives alittle higher gear ratio, helps in mud,but the massive cleats due the trick! the green machines looked to be dueing a fine job out there, I love to the small guys duing it, ab/sears/murray,ect. they out there driveing their buts off!!! that LADY out there was good with her narrow frame machine also! the pride these guys show in (GITTER DONE!!!) amazed the land owner, every place we all show up, they shake their heads and say never thought they'd do it!!! Thanks agin my BROTHER IN PLOW!!!
DaDuke of
Old 03-28-2012, 11:48 PM
dfreed's Avatar
dfreed dfreed is offline
I could have used the diesel, but I didn't need it. I only use that one when all the LIGHT work is done! See ya next year.
Dierik
Proud member of the NC Smoker Club
Originally Posted by esarvey View Post
Like I said in my earlier post, the mud soaked deisel boy parked his deisel, went and got a 20HP GAS MACHINE TO BLOW MY DOORS OFF!!!
Old 03-29-2012, 10:23 AM
cub123's Avatar
cub123 cub123 is offline
Somehow I missed seeing you plow with that machine Earl, was too busy pulling up logs with the 982 in the lower back field
