#51
Looking Good. Cant Wait To See It Done.
#52
Todd that is part of the face lift! I've never had bear meat before but my wife is as mean as one! Ok maybe she's a cuddly as a baby bear.
#53
Better watch it, buddy!
#54
If the bear was young, you could have been eating a cub and working on one too, lol.
Nice work. Are you using any chemicals in taking the paint of or just the wire wheel?
To many ideas, not enough time..... Cub Cadet 147 2050041u340160 42" Mower Deck, Snow Thrower, Tire Chains and Weights, Rotary Tiller 1, Brinly Sleeve Hitch, Brinly 10" plow, Johnny Bucket Jr.,42" QA NF Dozer Blade. Cub Cadet 1872 SGT 60" CCC deck. Parts 129 future plans =ported pump for 147, cast iron rear for 1872,129 frame and steering axle= ?wagon? |
#55
So far just the wire wheel. But I'm thinking of using some stripper sparingly. Keeping away from the gaskets. At least to get some of it off.
Make the best of each day , Todd Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! |
#56
Heh, look what I found tonight when I took the rearend cover off to drain the fluid!
I've checked each gear for a missing piece, nothing. So I don't know if the PO had a problem and fixed it or what, but nothing seems to be broken. The fluid, and inside looked very clean, so it may have been changed as a new gear was installed, only the PO would know I guess.
#57
Hope your Cub won't need "dentures" soon.
Better to find it now than after it gets hung in the spiders! |
#58
Your resto/clean-up is looking great! If it were me I'd double check and triple check the rear end,its easy to miss the obvious sometimes as for cleaning up the rear what I did on my 1200 was wire wheel the devil out of it and use one of those soft spongy sanding pads to clean it up then primed it. Your doing a great job , keep it up!
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake! |
#59
Glad you found it, before damage was done, Todd.
#60
Looking great! Thanks for sharing! I have me a 72 that has been under cover about 16 years now,.... . The broken tooth would have me looking real good.
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
