Old 01-27-2012, 08:52 PM
Guys
For those of you with Bota powered Cubs, I think I have found a one wire alternator that will fit the Kubota engines. Gotta check it out a little more but maybe we can run the PTO and the lights at the same time.
Sam
Old 01-27-2012, 09:36 PM
I have never seen a cyclops with front ports. Does anybody have a picture of the dash levers for the dual spool valve?
Old 01-27-2012, 10:53 PM
Dave01's Avatar
Dave01 Dave01 is offline
It's a 2nd lever that mounts above the normal deck lift one, you enlarge the slot cut in the dash panel to fit it. I don't have a picture handy but you can see me operating the levers in this video.
https://picasaweb.google.com/lh/phot...eat=directlink
1864 w/48" deck, 2084 w/54" deck + 54" blade, 3204 w/48" deck
Old 01-28-2012, 12:49 AM
Dave awesome video from last year!
Old 01-28-2012, 06:57 PM
Enjoyed your vid, Dave!
Old 01-31-2012, 05:23 PM
Update on my supers. Got the 2182 valves adjusted today. Talk about an easy engine to work on. Thing runs awesome! Gotta buy a PTO clutch for the 2182 thought I could get away with just a set of new bearings but after I pulled it apart I can see that the insulation for the coil is done. It still works but I doubt it will last or it would be one of those that as soon as it gets hot it craps out. Rebuilt the carb on the 2284 and have it running pretty good still need to fine tune on it a bit. I'm not a fan of the carb on a CH22, talk about a PITA. Tomorrow I hope to get to work on the polishing and waxing that they both need. I'll try to get some pics.
"The Darn Yankee"
Old 01-31-2012, 07:20 PM
Dave01's Avatar
It sounds like you've decided to keep the 2182 and sell the 2284, am I right? You might have said earlier, but how many hours on each?
Old 01-31-2012, 10:39 PM
Thanks for the update, Sam!
Old 01-31-2012, 11:08 PM
cub149's Avatar
cub149 cub149 is offline
Nice video. I want one of dem thar piar angle blades, oh well maybe one day.
Chip T.
Drexel NC
Old 02-01-2012, 07:19 AM
Dave
Yes the 2284 will be for sale, it has 510 hours on it. The 2182 has 475 hours on it. Both have 60" decks. I'm gonna keep the 2182 just because I think it's cool don't have a need for it. I use my BX to mow the large open area and my 1210 for the tight area. I should sell the 1210 but I'd never be able to get the $$$$ out of it that I have in it and it's also a cool little tractor.
Sam
