#51
![]() Quote:
I really hope it is ok!! |
#52
WOW your going to part a super to put power steering on a 782?
If I were closer Id take the rolling chassie off your hands. Id like to make a gear drive super. I have some engs and Id run a pump off the crank. |
#53
![]() Well, we have good news, and bad news. First the good.............................................. .................................................. .................................................. .................................................. ...................... Oh wait, there is no good news, ok on to the bad. I pulled the plugs, and the lines going to the remote filter. Then spun the engine with the starter, trying to prime the pump. I thought I was seeing some oil coming up the pressure sender port, then the spinning stop. The motor froze up. ![]() ![]() Can you say "start over from scratch?" ![]() ![]() |
#54
I'm hoping to use the dual rear brakes, front hydro ports, and the power steering. Then yes, peddle the rest.
#55
When you put the eng togeather did you use oil as your asembly lube or grease? I use grease. Also did you put a new pump in, or is this the pump that was in the eng?
On another note I was thinking of your heads last night and remember theres a guy on another forum that rebuilds carbs for motor cycles and he uses a soda blaster. So I got to looking at home made ones last night and going to build me one for carbs and Im guessing it would work well on the heads too. |
#56
MW
That sucks, hope it's not too bad. Vince Don't hold out on us with the soda blaster. Inquiring minds want more info. ![]() |
#57
![]() Quote:
Sob and other words,------- ok, looks like the crank can be cleaned up/saved, but it will need a rod. but WHY didn't it pump oil, is the question! did the block have that problem when it was a gen set? the letdown is a bummer to say the least! I feel your pain!! Now I really want to know why no oil, as well as you |
#58
![]() Quote:
As far as the oil pump, it is intact and appears to function as it should. The only thing I can think is the the dummy that built the engine didn't use enough assembly lube, and failed to correctly prime it. Oh wait, I'm the dummy that built it!!!!!! I belive that the addition of the remote filter, may have played a part. The filter did have some oil in it, but it never filled all the way. This time I will be more generous with the assembly lube, leave the heads off, and prime it on the bench. |
#59
Just a thought but you may want to use a small pump or some kind of tank that you can pressurize to prime the system before turning it over. I'd hook it up to the line that feeds the filter.
#60
Yes, That's what I'm noodling on. I will fill the filter, and lines prior to ever spinning it over. I have some thoughts on how I will prime it, I'll post more when I sort it all out.
