Old 10-06-2012, 11:49 PM
The 108 is looking good, Andrew!
Old 10-07-2012, 08:35 AM
Oh yeah!
Old 11-11-2012, 08:12 PM
Andrew_deaton's Avatar
Andrew_deaton Andrew_deaton is offline
hey guys this is now forsale on craiglist and the forsale section check it out and someone pleaase buy it!
Old 11-22-2012, 12:24 PM
Well thanks to Sam I now have a nice deck for it and a clutch so I will be posting pictures soon of the deck and hopefully a video of it running and cutting
Old 11-22-2012, 01:33 PM
BigB87's Avatar
BigB87 BigB87 is offline
looks great andrew. i had a 108 but sadly had to sell it. but looks great for ur first tractor.
Brandon
CC models: 86, 100 w/hanban sickle mower & 1872
1972 86 w/12" brinly plow & 65lb wheel weights & 42" grader blade
1965 100 w/hanban sickle mower
1989CCC 1872 w/50c mower
Old 11-22-2012, 02:44 PM
I'm diggin' the headlights. Got a pic of how you got those mounted?
Old 11-25-2012, 12:41 AM
I will take a pic tomorrow of the headlights long with a picture of the deck after i clean it up alittle. I got a call today with a guy interested in buying it so im really hoping he jumps on it because I really need the money. If not youll be seeing it on here hopefully complete
Old 11-25-2012, 05:18 PM
Here is how I mounted the lights.
I bought some walmrt headlamps and I took the original reflector for the front and cut 2 holes the size of the glass on the lens with a plasma cutter. Then i welded some sheet metal to each side and cut out a hole of the prongs on the headlamp. Next came a bolt welded in the center and holes drilled in the sheet metal to slide over the bolt. add a nut and its all done. I also added some foam to make it alittle more secure.
Here is a closer picture.
Today i went out to get the last part i needed for the deck and ended up coming home with this for FREE!!!
Old 11-25-2012, 08:22 PM
Well its painted!! sorta... I forgot to do the mule. So tomorrow ill take the mule apart and get it painted and have some pics up it and hopefully some of the assembly!!!!!
PRIMED!
PAINT!
I shot everything with some DG primer and some single stage black. I didnt have any yellow and i think the black will look better than white
Old 11-25-2012, 10:14 PM
Looks good! Thanks for the pics.
