Old 11-04-2012, 06:56 PM
Looks bad from here.Maybe some JB weld will fix er up...
Up to 534 and counting...
Old 11-06-2012, 08:52 PM
Straightende the drag link and tie rod. They were both bent pretty bad.
I don't have a torch to heat anything so I went to the next best thing, wood stove
I got the two of them red hot and put them in the vise and now all is strait again. Didn't want to paint anything on this tractor, but I couldn't leave them all burnt looking.
Now just waiting on some parts for the steering and front wheel bushings and she'll be as tight as a new one.
Old 11-06-2012, 10:11 PM
Great job, Todd!
Old 11-06-2012, 10:27 PM
Great job, Todd!
X2!
Looks like I need to get that care package out to ya!
Old 11-07-2012, 02:32 PM
X2!
That would be good
Whenever you get a chance.
Old 11-07-2012, 02:44 PM
PaulS's Avatar
PaulS PaulS is offline
That forge looks strangely familiar. Is that a Fisher stove. I have the papa bear but have never used it to heat metal.
Old 11-07-2012, 06:26 PM
jbrewer's Avatar
jbrewer jbrewer is offline
Default to paint or not to paint
Great work Todd.
I paint whatever it is I'm working on ... if not I make sure it's not rusting away and otherwise leave it the way it is. I kind of like the "rat rod" look of honest wear and tear (and in the case of my O outright abuse and neglect)
Good work!
John
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 11-07-2012, 08:59 PM
Yes it is a Fisher stove.
Thanks for the comments all.
Old 11-12-2012, 09:27 PM
Default cleaning
Took the engine back out today, thought that I got a gasket set for it I might as well get rid of some oil leaks.
Took off the oil pan, and thought I should take the head off as well to de-carbon the head, wow! Found out it's been punched 10 over sometime in it's life, and has a good bunch of carbon. So going to clean things up in there and do a valve job and put it back together. The little I had it running there wasn't any smoke. The oil that's in the picture was some I put in the plug hole and turned it over good before I tried starting it.
I'm not going to spend alot of time redoing everything, just cleaning it up to run better
Or!
Old 11-12-2012, 10:08 PM
Thanks for the pics, Todd! The 100 will run great, when you're done with it.
