Old 04-08-2013, 12:54 PM
timbo2's Avatar
timbo2 timbo2 is offline
I have my come-a-long ready to go.
Is this where you attach to the M20 to lift it out?
- Tim
Old 04-08-2013, 01:06 PM
You should have a lifting lug on each side to balance it.
Old 04-08-2013, 01:22 PM
timbo2's Avatar
Thanks Sam,
I'm glad I checked, it was missing on the other side and my 1872 had both sides so I'm borrowing a lug from the M18.
I should get the engine lifted out this week while waiting on my Flywheel puller to get here.
take care
- Tim
Old 04-08-2013, 05:27 PM
Donovan M.'s Avatar
I hope you figure everything out.
Donovan:
62' Original-fenders
Old 04-13-2013, 01:41 PM
timbo2's Avatar
Ok arranged and cleaned up the garage this week while waiting for the Puller to arrive and today it did.
Flywheel popped off with a little patience. I also sprayed it periodically this week with PB blaster knockoff. I alternated the hole sets that I used on the flywheel and thats when it popped. Also tapped the center bolt with a hammer as I tightened the puller.
here are some pics, just want to be thorough for whoever reads through this thread. hate it when you read a thread and never find out what the solutions were.
Should get new Stator on tomorrow and will update after I get it put back together and fire it up.
- Tim
Old 04-13-2013, 02:02 PM
Thanks for the updates!
Old 04-13-2013, 06:10 PM
Appreciate the update and pics!
Old 04-13-2013, 07:46 PM
Good to hear!
Old 04-16-2013, 09:13 PM
timbo2's Avatar
Ok gang, we have this one solved.
Charging system is fixed. I put on the new stator(tested it, no shorts to ground like the old one), put engine in and hooked everything back up and no shorts/blown fuse and getting 14vdc off the voltage regulator.
I also put in a new coil while the flywheel was off, the PO included a new one in the purchase, so Ill keep the old one for a spare on the 1872 or 2082.
Thanks to all and time to wrap this thread. I'm sure I'll have other projects but for now time to get ready for mowing.
Take care!
- Tim
Old 04-16-2013, 10:33 PM
That's awesome! Glad you got your charging issue fixed!
