Old 09-28-2013, 08:43 PM
Nightow1 Nightow1 is offline
ROfL. Yea I seriously just noticed that. I got this as payment for so computer work and never even thought about it till I finished her and then SH#@ myself. I have no idea what to do now. Lol . Well it's a nice looking paper weight.
Old 09-28-2013, 09:13 PM
cant I just get a wide sub-frame and lift bar?
Old 09-28-2013, 09:17 PM
OldAndInTheWay's Avatar
I got one that would fit your machine. We could just trade.
You could do your restore all over again.
Pickup might be a problem... How far are you from the Northern Shenandoah Valley of Virginia?
Old 09-28-2013, 11:09 PM
If you were closer I would seriously consider that.
Old 09-30-2013, 07:06 PM
Default subframe?????
Ok I have a extra sub frame for a wide frame mower deck, the only difference I see between this one and the real wide frame subframe are the the holes to mount it to the blade are smaller. Has anyone done this.or do you think it will work to just drill out larger holes and attach it to the blade?????
Old 10-25-2013, 12:53 AM
Haven't updated in a while, Member Rescue11 and I have done a lot to the old girl. Replaced head gasket, and all the engine gaskets except the Crankcase ones they were good. while it was apart honed down the Heads and cleaned them and the valves Ect. Cleaned the engine and frame up. Added a electronic fuel pump , oil pressure gauge, lighter new LED safety flashers and a implement light. Relocated the hour meeter to the right side just under the fuel tank.. drained and purged the fuel tank. New 5w-20 synthetic oil and IH Hy-Tran + filters. New fuel filters. Greased everything. New plugs and wires. New point saver. New solenoid and coil.and New points. Put on the winter tires and chains + 200lbs of wheel weights. 25lbs IH weights on the inside of each tire and 75lbs cub cadet weights on the outside of each tire.
We also finished up the blade came out great. Cant wait for some snow.
Old 10-25-2013, 10:51 AM
Rescue11's Avatar
Rescue11 Rescue11 is offline
That cigaret plug came out awesome!
1- 1200 in pieces
1- 1864 in pieces
Old 10-25-2013, 09:38 PM
Thanks for the update and pics!
Old 10-26-2013, 08:29 AM
My girl modeling for the camers.
Old 10-26-2013, 08:44 AM
Cool night pics!
