Old 11-26-2013, 07:08 PM
Nixon327 Nixon327 is offline
Thanks Cecil. I'm trying. It may take a little while. But I will get there.
Cub Cadet model 70
Cub Cadet Model 109
Definitely a work in progress!
Old 11-26-2013, 07:23 PM
Keep up the great work!
Old 11-26-2013, 07:54 PM
EricR's Avatar
EricR EricR is offline
Holy crap I have never seen a frame that far gone but so far you are doing great.
#10-149 with a 38inch deck.
2015 Kubota BX 2670.
Old 11-27-2013, 07:55 PM
Well I got a little more work done on the cub. I removed the rear tires, pulled to axles (which to my surprise looked really good). Pulled the axle tubes ( which were full of water That also surprised me. Not because it was in there but because I thought I had drained it all out). Had my helper with me while I was taking the tires off. Momma said it was time to come in. Have to get to bed early have a long day tomorrow.
Cub Cadet model 70
Cub Cadet Model 109
Old 11-27-2013, 08:05 PM
bluesman bluesman is offline
Thumbs up
Man, those are cool looking rear wheels. Good luck, I'll keep checking on this thread. Sure to be a lot of good info here by the time you're done.
Old 11-27-2013, 08:09 PM
Thanks bud! I am hoping to gain to most possible knowledge about cubs during this awesome excursion.
Cub Cadet model 70
Cub Cadet Model 109
Old 11-27-2013, 08:17 PM
Your thread title is a complete understatement.
You're doing well so far and I wish you continued good luck
Jeff
Old 11-27-2013, 08:32 PM
Jeff
Yeah that's what I was thinking! lmao! Thanks Jeff
Cub Cadet model 70
Cub Cadet Model 109
Old 11-29-2013, 07:47 PM
Well. I tore down the rest of the transmission. The needle bearing that the main shaft rides on is toast and gouged the shaft. I wonder if I can mill that down and run a little bit bigger bearing. Maybe that would be easier then trying to find a new shaft. I'm thinking that I should go ahead and replace all of the bearings. They are 50 years old. Definitely wouldn't hurt. Let me know what you guys think.
Cub Cadet model 70
Cub Cadet Model 109
Old 11-29-2013, 09:20 PM
cjrolke cjrolke is offline
wow
just wow
good luck
