Old 03-29-2014, 09:15 PM
Well, pulled both the Lo-Boys in today. Did the tire/wheel swap on both tractors. Decided to go ahead and see if I could get the 185 to fire up. Finished installing the ignition. New plugs, wires, cap and rotor. Filed the points. Put some fresh gas in, no leaks. Hooked up a battery and no smoke rolled. S/G didn't want to crank it over so I took it apart. Cleaned the brushes and the comm with emry cloth, put it back on.... MUCH BETTER. Whirled it right over. Actually, it fired right up! Ran pretty good too! Here's a vid after I'd had it running once, so it was warm. But, it started almost that fast the first time! (OK, well I had to choke it the first time. ) It doesn't have a driveshaft in it, as the clutch is bad, so I removed it today. Hydraulics work, and so did the ammeter (kinda, it's not centered) and the oil light. Lights didn't work, but I didn't look into that any. PTO worked too!
Click on the pic for the vid.
Old 03-29-2014, 09:43 PM
Sounded good Jonathan!
Old 03-29-2014, 09:51 PM
Thanks Mike!
Old 03-29-2014, 10:25 PM
That's a great running Lo-Boy, Jonathan!
Old 04-07-2014, 01:55 AM
Put a new set of boots on the front of the 185 this weekend. I bought that other 154 Lo-Boy for the narrow tires and wheel weights. Switched them over last weekend, and ordered new tires for the completely SHOT ones on the front. After I fix up the 154 and sell it, the 185 will be getting a brand new set of Firestone 23° ags on the rear. (Probably need to get a clutch in it next. )
Old 04-07-2014, 06:25 AM
Looking good Jonathan.
Old 04-07-2014, 07:39 AM
Way Cool Bud!
Old 04-07-2014, 09:37 AM
Thanks Nick and Sam! I don't want to mount any more of them anytime soon. Those narrow tires with a tube were a bear! Easy to pinch a tube (which I didn't thankfully). I did, however, use a de-scaler and wire wheel on the inside of the rusty, rusty, rims and prime and paint the inside before mounting the new tires.
Old 04-07-2014, 10:15 AM
The new fronts look great, buddy!
Old 04-07-2014, 10:33 AM
Thanks Allen! I like them. I think it will make it steer easier too. Just sitting there, it turn a lot easier than before.
