Old 05-26-2014, 12:46 PM
inspectorudy's Avatar
I wouldn't go 50/50 because you want the mix to evaporate as quickly as possible. I would go with a couple of table spoons in a glass of tap water. As long as it feels slippery on the decal and not just wet it will work. Another good trick is to use painter's tape to set up your straight edge so that you can get the decal on plumb. Then just pull the tape off after the decal sets up or whenever you are satisfied.
1811 Hydro
Old 05-26-2014, 10:08 PM
weatherby's Avatar
weatherby weatherby is offline
A few more pics.
I think what I am going to do is, put this 1811 together, and add the power steering to the 782 when I begin to restore it. That way, I will have the time to find all the parts for the power steering.
Thanks for the tips on the stickers.
Old 05-26-2014, 10:13 PM
It's getting there! Thanks for the pics.
Old 05-27-2014, 10:26 AM
Man oh man, just seeing that 1811 in that picture makes me drool for putting in power steering. At this point it would be so easy to do it compared to doing it like I did it with everything in place. I understand your motive because it does take a while to gather all of the components. If your 782 ends up like your 1811 then you will have an easy time installing ps in it. I am amazed that someone entrepreneur hasn't come out with a ps kit for the thousands of CC out there.
1811 Hydro
Old 05-30-2014, 10:45 PM
weatherby's Avatar
A few more pics...A before and after pic of the hydro lift lines, and the engine was put back in along with the battery box.
I also rebuilt both ends of the drive shaft...forgot to take pics of the ends before I re-installed it
Old 05-30-2014, 10:53 PM
weatherby's Avatar
I also had to replace the drive shaft flange assy. (engine end of shaft)
Old 05-31-2014, 07:06 AM
If that first pic of the driveline is an after pic, it looks like your rag joints are too tight. Everything else is looking top notch. Good job.
Old 05-31-2014, 10:33 AM
Good work!
Old 05-31-2014, 09:02 PM
weatherby's Avatar
I agree...I reduced the toque on that rag joint after that pic was taken
Old 06-01-2014, 11:10 PM
weatherby's Avatar
I don't know why...But I keep getting an error when I try to post any pics, It's been like this for the last two days.....It says..."A generic error as occurred"
Any ideas why?
