Old 11-01-2014, 07:17 AM
mickb72 mickb72 is offline
Default cub
Hi Sam, Wow that table and hoist really takes the work out of it. Gonna lose an hour of cub time tonight. Are you still in for that snow? Mike
Old 11-01-2014, 07:26 AM
Mike
Without the lift and hoist I wouldn't be doing these things, my days of working with jack stands laying on my back are long over.
We have about 2" of snow on the ground at the moment. I'll post some pics later in the general area.
Old 11-01-2014, 09:41 AM
jimbob200521's Avatar
Good progress pics, guess you gotta have something to do during those snow storms
On the driveshaft; I think it was a great idea by Cub to make them greaseable, however I don't think that anyone outside enthusiasts knew about it, or so it seems. It's gotten to the point of habit whenever a Cyclops comes into the shop to pull the drive shaft, clean it up, and start with fresh grease.
-Ryan
Old 11-01-2014, 09:46 AM
Mike
The November HF sale ad has a motorcycle lift on sale, I wonder if it would lift a Cub Cadet??
Only rain, here!!
Old 11-01-2014, 09:55 AM
Only rain, here!!
John
I had one of those HF motorcycle lifts. I tried it with my 1210 and decided it was not stable enough. Scary flexible. It was pretty well maxed out with this on it.
You may want to look into something like this.
http://www.discountramps.com/atv-lift/p/BW-1500AO-V2/
The lifts that CubCrazy and I have were made by these guys
http://www.advancelifts.com/Producti...A3H1_AT_W.html
Mike found them on C-List at a surplus place in PA, supposedly they came out of the Harley factory.
Old 11-03-2014, 05:21 PM
Got a little more done today. Pressure washed the rear and the frame. It was one nasty creature! Patched up the muffler. The end was rotted out and the PO had about 2 lbs of bird poop weld on it. Just cut it back and welded a flat plate on the end, made a ring to surround it and used an old PTO bushing for the tail pipe, a few minutes with Mr. Miller and that was done. I don't feel like buying a new muffler for this till I know if it's worth saving. Rear is on the work bench ready to be torn down. Got the new PTO bearings and some of the seals for the rear, need to order a couple more things, didn't plan on opening the pump but I noticed a few oil tracks under the seals so while it's out I may as well do it and be done with it, then the wrenching will begin. It's now officially cocktail hour as you can see looking at the top of the frame, LOL.
Old 11-03-2014, 11:01 PM
Berwil's Avatar
Berwil Berwil is offline
Sam, I want your retirement when I grow up. Nice work!
Bill
Old 11-03-2014, 11:05 PM
Bill
I'd settle for some free time to play with cubs.......
Nice work as always Sam!
Old 11-04-2014, 09:37 AM
IDK about you Sam, but when cocktail hour in my shop begins, that when the real work gets done Looks good, thanks for the pics!
-Ryan
Old 11-04-2014, 09:39 AM
Darrell Darrell is offline
I have never worked on this style of tractor and i was wondering if you made the cover plate for the rearend ??? It doesn't look like the usual stamped cover for aluminum rearends.
And what are the ladder bar mount looking thingies for ??
Those axle tubes look HUGE !!!!
