#51
Correction;
the flex disc part number is 722-3000 |
#52
I bet one could make them if they tried. I have some old mud flaps, I may try that.
I lost track of what I own a long time ago! |
#53
![]() Mud flaps don't have the reinforcing in them. They are mostly rubber, and soft rubber at that. The flex disks are more like a tire. Also, I'm gonna say you never tried drilling a hole with a hole saw in rubber. They're worth the $15 for the flex disk. |
#54
#55
I sell mudflaps-they are made from leftover rubber at the hose/belt factory. There's just enough cord inside to hold them together, most fail at the bolt holes. No way they would hold up.
#57
#59
I'll give my 2cts saving a $ or cutting corners is fine with some things, but not a good idea always. Oh you may be able to make a rag joint yes. Will hold up is the question? And if not do you want to find out the hard way that it won't? Better to spend $15 now than 10x that or more when the homemade one fails.
Brian April 1979 1200 Quietline 44A deck 1988 1211 customized into a 1288 with a K301AQS 38C deck and a 1864 54” deck . Snow blades 42" and 54" . Brinly disk, brinly plow a cultivator and a $5 brinly yard rake!
#60
Ya got that right Bo!! My sentiments exactly
No need to get in a pissing match here! |
| Tags |
| clutch, cub cadet 1200 quietline, rag joint |
