#51
I'd have to remove the tunnel cover and look at the rear of the shaft again, since I'm trying to envision how the fan could be removed from the shaft without uncoupling the front and removing the pin. I've only ever had all that stuff apart once and so looked back at the (many!) pictures I took so as to know how to put everything back together again once done.
#52
Interesting. So there is a driveshaft made for these that doesn't have the pin. Didn't know that. It would make the job much easier.
#53
It still uses a pin in the lower one. The upper has one in it.
#54
I'm confused...if they both have (and use) pins, how is it easier to install a fan?
#55
The back coupling comes off.
#56
Hey folks. I hope you can help me with this. My Cub Cadet 1572 is missing the hydro pump cooling fan. I ordered what I believe is the correct replacement fan for it, but the fan has a 5/8” hole and my driveshaft is 3/4” diameter. I suspect the driveshaft was replaced at some point because it has no clutch, just the old style rings. Can anyone tell me what fan has a 3/4” hole and uses a small bolt and nut to secure it to the driveshaft? Thanks.
#57
The part # is 903-1434.
