Old 07-24-2016, 06:51 PM
vr4Legacy's Avatar
vr4Legacy vr4Legacy is offline
I think he mean, what is the OHM rating of the coil you posted on Amazon. It doesn't say.
Originally Posted by twoton View Post
Jason, Should be 3.2 to 3.5 ohm, internal resistor coil like this one.
Gotcha. I cross referenced the Cub Cadet P/N off the parts finder.
Kohler P/N KH-41-519-21-S
Stens website says it fits Kohler K91-K361
https://www.stens.com/460-048-ignition-coil
Although I can't find resistance values anywhere. I trust the site has it right.
And I agree with the cost does not equal quality argument. And vice versa.
Jason, Should be 3.2 to 3.5 ohm, internal resistor coil like this one;
This is confusing because the link in the technical thread says the value should be 4-8 ohms. Or do those readings not necessarily match?
-Jason
Cub Cadets: 1200 | 149 | 1650 | 122 | Z-Force S 54
Implements: QA42A | Push Blades | #2 Tiller | Rear Blade | 223A Utility Trailer | And a few mower decks
Gravelys 5260 | CI Walk-behind (Project)
And a couple of Subarus
Old 08-07-2016, 05:00 PM
vr4Legacy's Avatar
Went out this morning and put the new coil in. Turned it over and... nothing.
Then I double checked everything, and apparently the coil doesn't do any good without the coil wire connected to the spark plug
Fired right up once everything was hooked up Spent a few hours mowing and everything went great.
As I mentioned in TwoTon's post I kept having problems shredding 1/2" belts. So after some researching I found a belt cross-reference guide and it had the belt size listed as 3/8"x81. (2nd pic) So I ordered one and it seemed to do much better.
I decided to check things over a little more closely just to see if anything was amiss with the mule drive and noticed one of the pulleys looked askew. I think that is the source of my issues, you can see in the pic how much hit tits compared to the one on the left. The 3/8" belt is thin enough it doesn't rub much, but I'm sure that's what the 1/2" belts were rubbing on. I could see wear on the 3/8" belt.
I'm going to swap out the mule drive from my 149 and see how it does. The pulleys don't have much play in them.
-Jason
Old 08-07-2016, 06:06 PM
twoton twoton is offline
Here's one of mine. Looks to be a lots of slop in the right pulley bracket on the one in your picture.
Old 08-07-2016, 08:42 PM
vr4Legacy's Avatar
Yep. Lots of slop. I checked the one on my 149 and it's much better.
I'm going to swap out the mule drives and see how that works.
Thanks for the pic!
-Jason
Old 08-28-2016, 05:30 PM
vr4Legacy's Avatar
Went out and mowed some more today.
I took my other mule drive out and tried to put it on, but I think it's bent, I had trouble lining everything up. They hit something because the front of the 149 is bent up too. I did however swap out the pulleys. You can see what the issue was from the pics. Mowed great and the belt looks great after 1.5 hrs of mowing.
I think the driveshaft may be a little bent because it seems to vibrate and rattle a lot when I let out the clutch. Looking at it thru the creeper hole while it's spinning it looks like it may be a little bit bent. I don't think it's enough to hurt anything, but it vibrates.
-Jason
Old 08-28-2016, 05:33 PM
Could be worn out ball bushings...
Old 08-28-2016, 11:08 PM
bocephus1991's Avatar
Whatever it is I'd look into it before you tear something up.
Brian
Old 08-28-2016, 11:23 PM
Vibration / runout will wear other parts quickly.
Old 08-29-2016, 09:50 PM
vr4Legacy's Avatar
Yeah.
Dang it, why do you guys have to have so much reason and sense?? lol
I'm buttoning up the PTO rebuild on the 149 so hopefully I can use it to mow next time. I'm getting tired of working on these things in the 95 degree heat. Luckily, with said heat, the grass isn't growing very quickly and I shouldn't need to mow but a couple more times this year.
How can I check the ball bushings?
I laid a straight edge on the driveshaft and it appeared to be straight when I had it out. But I didn't remove the clutch/discs so it could be off there.
-Jason
Old 09-04-2016, 11:05 PM
vr4Legacy's Avatar
I've been thinking this over and read another thread that reference 2 ball bushings.
Are there two balls also? I only have one in the back of mine.
Nonetheless, I'm going to haul the 149 over soon and bring back the 1200 and take out the driveline. I think I'll pull the clutch, spring, plates and all off the driveshaft and check to see how straight it is.
I"ll also take off the driver and see what the bushing looks like behind it.
Any easy way to test the bushings? Just make sure they moving freely like any bearing?
Thanks again everyone for the all the input. I know this thing will be running smooth eventually, just getting a little frustrated getting there. (or perhaps my wife's frustration is rubbing off...)
-Jason
