Old 07-24-2016, 09:01 AM
RedOnes's Avatar
RedOnes RedOnes is offline
HTML Code:
you'll have to drill and tap the pump input shaft.
IMHO ..drilling and taping a hardened shaft is not for the faint of heart
Frank
IH 982 , 3 point
CCC 782
Old 07-24-2016, 10:32 AM
OldSkull's Avatar
OldSkull OldSkull is offline
Originally Posted by RedOnes View Post
HTML Code:
Agree and angle head drill like the one in Sam picture is a PITA to level in a narrow space. Time to pay a visit too Mr Drill Doctor or the grinder, you gone need a sharp one!
Gilles ....your tools look like they have never been used in 20 years ...you should see mine
..been in my toolbox since 1968
Frank. I take this picture from Google, mine never look like that it's an inheritance from my father I don't even know how old they are.
Gilles.
1963 100 (red)/in storage
Old 07-24-2016, 10:42 AM
Actually it was not all the hard to do. I used an old adapter as a drill guide and the shaft is only case hardened so just go slow and it's no big deal.
Old 07-24-2016, 10:48 AM
OldSkull's Avatar
Good tips Sam, thank you for sharing.
Gilles.
Old 07-24-2016, 11:03 AM
Also I only drilled it to the point that it intersected the factory hole for the roll pin. Tapped it 1/4-28.
Old 07-24-2016, 11:15 AM
aagitch's Avatar
aagitch aagitch is offline
Sam, what adapter is needed for the engine output? I had assumed it would be one from an 1882 but i can't even find it in the parts lookup.
Adrian
2072 (789513)
Old 07-24-2016, 11:41 AM
1872 already has the proper adapter. Standard Kohler/ Cub. Four 1/4" bolts on a 2.2" bolt circle.
Old 07-24-2016, 11:43 AM
Originally Posted by CubDieselFan View Post
Also, I have a 1864 drive shaft and cv joints on the shelf so would that work in the 1872 with the proper adapters?
You can sell the 1864 shaft to someone with a 1772 or 1572 that wants to do a CV conversion.
Old 07-24-2016, 03:18 PM
CubDieselFan's Avatar
I have 2 sets of 1864 parts, and the 1772 and the 1572. The 1572 does not need it now and the 1772 does so it is a future project as well.
Old 08-06-2016, 11:23 PM
Just to be clear, I only need the adapter from Jeff on the rear. The 1882 CV adapter will bolt up to the Kohler crank adapter? Thinking about doing this.
